Timing Belt & Water Pump change
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> DIY Requests >> Timing Belt & Water Pump change Page: [1]
Login
Timing Belt & Water Pump change - 8/16/2006 10:18:32 PM
Island Accord
Score: 0
Status: offline
Hi, I was wondering if anyone knows if there's already a write up on changing my timing belt & water pump.
BTW I have a 2001 Accord LX, 4dr, 4cylinder.
If there already isn't a write up on this, can someone guide me through this process? Also, I spoke to one of the salesperson at an auto parts place and he recommended changing some other stuff (ie. thermostat, thermostat gasket, radiator hose upper, radiator hose lower) is this correct? Am I missing anything? Please help!
Post #: 1
RE: Timing Belt & Water Pump change - 8/17/2006 12:29:31 AM
deserthonda
Score: 0
Status: offline
quote:
ORIGINAL: Island Accord
there is no write up yet,, i am waiting to see if TONY1m ,, ( doing the t-belt and taking pics , hope he will give us some so i can do a write up with pics ) I would advice to get a service manual www.helminc.com
when doing the t-belt you do need to replace other parts but not what the salesperson suggested.......replace the water pump, cam, crank, balancer shaft seals, valve cover gasket , alt p/s belts ,, no need to replace t-stat unless car overheats and the radiator hoses replace if needed, feel the hoses,, if they feel too soft or crunchy replace them ..
< Message edited by deserthonda -- 8/17/2006 12:30:47 AM >
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
(in reply to Island Accord)
Post #: 2
RE: Timing Belt & Water Pump change - 8/17/2006 3:25:02 AM
Island Accord
Score: 0
Status: offline
Thanks for the quick response. How would you rate the difficulty of doing these procedures for a person who has very little knowledge about fixing cars? Also, I forgot to mention it's a 5 speed manual transmission Accord. Does that make a difference?
< Message edited by Island Accord -- 8/17/2006 3:27:21 AM >
(in reply to deserthonda)
Post #: 3
RE: Timing Belt & Water Pump change - 8/17/2006 8:23:57 PM
SKHEMR
Score: 0
Status: offline
SKHEMR's photo gallery
There is one more belt that needs to be changed, the balancer belt. Once you get that damn crankshaft bolt off and remove the pulley it's pretty easy. That bolt sometimes is very hard to take off. I didn't do all the work but that's what I remember.
Change the timing belt is no joke if you never done this before because if all the gears are not lined up at TDC (top dead center) you can mess up alot. There is a little white line on the pulley that tell you where tdc is.
Post #: 4
RE: Timing Belt & Water Pump change - 8/18/2006 12:28:45 AM
deserthonda
Score: 0
Status: offline
if you look at the post written by TONY1m ......
92 accord timing belt replacement,, it has all sorts of pics ans tep by step instructions
your car is a bit different but the set up ot the belt, balancer sahfts , is the same
top dead center alignment on you car is on the crank pulley and the notch on the lower timing belt cover,,
< Message edited by deserthonda -- 8/18/2006 12:31:06 AM >
No Help from me
Post #: 5
RE: Timing Belt & Water Pump change - 12/8/2006 3:56:43 PM
RoKnAzn
Score: 0
Status: offline
Any updates on the writeup?
Thanks
Anthony
Post #: 6
RE: Timing Belt & Water Pump change - 12/9/2006 7:30:22 AM
s20700134
Score: 0
Status: offline
I would like to see a write up on 5th gen accords. That would be nice. I've had my car for a few weeks. Im bad tho cuz i replaced the fluids(tranny, coolant, engine, bled the brakes and new fluid, abs, p/s, and even the winshield washer fluid.) and did a used japan tranny swap. But, i have yet to do the timing belt. im kinda dreading it. I saw all the steps in the haynes manual(i know i know, i wanna c a write up and all, but a write up WOULD be nice, am i right?) and it just makes me wanna say eff it to it all. (the revelance of this post, i really dont know, sorry, kinda out of it.lol)
1997 Accord EX Coupe AUTO
Removed intake resonator box
painted black headlight housings WITH electric tape eyelids!
electrical tape over the chrome moldings
removed amber form tail lights
kenwood I.C.E.
SMASHED FRONT END
OH, and its blac
(in reply to RoKnAzn)
Post #: 7
Page:   [1]
Honda Accord Forum >> General >> Do-It-Yourself Section >> DIY Requests
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6827
sir_nasty6303
falkore245649
00accordlx5s3797
deserthonda3574
finch133238
jimblake3131
19accord973125
live2rice2622
smaglik2594
New Vendors
Sportwing
