Twist Tie Fell Inside Spark Plug Hole!
  Printable Version
Honda Accord Forum >> General >> General Tech Help >> Twist Tie Fell Inside Spark Plug Hole! Page: [1] 2   next >   >>
Login
Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 11:53:11 AM
92_accord_honda
Status: offline
Yes, this is going to sound awful, but when I was changing my spark plugs, there was oil in the far right hole. So, in a dumb idea, I used a twist tie at the end of a metal rod to attach a rag, and the twist tie came off and fell into the spark plug hole, and I can''''t see it. Do I have to take off the cylinder head to remove it, or can I fire up the engine and it will burn it up? The only way I can think of to get it out without taking the cylinder head off would be to stick a tube inside and have it attached to a vacuum, or a magnet on a string, either of those ideas sound like they would work? How much space is inside underneath that one hole?
< Message edited by 92_accord_honda -- 9/24/2008 12:11:19 PM >
Post #: 1
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:09:53 PM
live2rice
Status: online
live2rice's photo gallery
doesnt seemlike a good idea to fire it up, as twist ties have a metal piece inside that could/will cause damage
_____________________________
Need H22 or H23 OEM parts? Ask me.
1997 Fiji Blue Pearl CD7
1995 Sage Green Metallic CD5
(in reply to 92_accord_honda)
Post #: 2
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:18:07 PM
finch13
Status: online
raise whichever cylinder to TOP DEAD CENTER and stick they ol'' vaccum in.
USE ME TO SEARCH HAF
99 Accord F23A1 5MT
(in reply to live2rice)
Post #: 3
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:26:35 PM
live2rice
Status: online
damn nice new sig pic there finch
(in reply to finch13)
Post #: 4
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:31:31 PM
Fenix
Status: offline
Fenix's photo gallery
autozone/barn sells thin magnetic probes, perhaps small enough to get in the hole. You''d be fishing in the dark for the twist tie but it may save some time. Magnet on a string is a bad idea cause you could end up loosing the magnet in the hole too.
04 EX 4cyl 5AT Coupe
Fujita CAI
Custom Heads & TYC Tails
Apexi WS2 Cat Back Exhaust
Front Grill
Interior LED rods(7color)
20% Tint
TSX Intake Manifold
DC Ceramic Header
Ralco Light Weight Pullies(In Hand)
Post #: 5
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:38:22 PM
finch13
Status: online
wait is it a twist tie (bread bags) or a zip tie? lol... yeah if its a twistie use a magnet.
quote:
ORIGINAL: live2rice
Thank man... I finally got around to making one... it''s only temporary, I don''t like the glare off the lights, but it hides the fact that my car isn''t modded and has steelies on it...
99 Accord F23A1 5MT
Post #: 6
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:45:25 PM
live2rice
Status: online
i think the glare makes it jdm yo, heres what you do you make the glare red so it looks like this
Post #: 7
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:50:06 PM
finch13
Status: online
HAHHHAHAHAHAHA
Fawk yeah! A rising sun at dusk would be mad JDM yo.
99 Accord F23A1 5MT
Post #: 8
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 12:52:25 PM
falkore24
Status: online
falkore24's photo gallery
I''d try the magnet .... it''s not going to be easy since it''s going to stick to everything in there, but worth a try.
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
Post #: 9
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/24/2008 2:31:17 PM
jerrym
Status: offline
Empty out a small shop vac. Use a smaller diameter piece of hose that will fit in the plug hole and suck it out. With a clear hose you might even see it go by!
JM
(in reply to falkore24)
Post #: 10
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/26/2008 7:42:58 PM
HondatechAV6
Status: offline
ewww... perhaps a long pic would help. they sell long pick tools at sears. i''d advice against starting it up. the plastic could melt and mess with the compression/oil control rings or could fly up and, worst case, bend a valve.
Honda Platinum Certified - A.S.E. Master Tech
I'm just a nice guy
(in reply to jerrym)
Post #: 11
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/27/2008 6:19:39 AM
TexasHonda
Status: offline
Why not start the engine w/ the spark plug removed for a few seconds. This will blast air out the spark plug hole and hopefully eject the wire-tie.
See you down the ROW
1994 Accord EX
(in reply to HondatechAV6)
Post #: 12
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/27/2008 10:05:04 AM
Tony1M
Status: offline
I''d lower the piston to it''s lowest point and then reach inside with this very inexpensive tool:
The lowered piston should give the tool enough room to bend-and-slide into different locations around the top of the piston.  Then you can extend and retract the grabbing fingers at each location.  As long as the tie is not laying perfectly flat on top of the piston, doing that several times should grab the tie and allow its removal.
If the tie is indeed lying flat, put a small magnet inside the grabbing fingers.  Wrap a layer of electical tape around the fingers to secure the magnet in position.  Make sure the tape itself is secure!  Then lower the fingers w magnet into the cylinder and go fishing for the tie.
Good luck.
Tony
1992 Accord LX, 4AT, 4 dr, no AC, no power anything
(in reply to TexasHonda)
Post #: 13
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/27/2008 10:17:41 AM
Tippman7641
Status: offline
first try to use a flash light or a camera and see if u can see where it is... then use the deive, but yeah no magnets on strings and dont start,, mabe crank(if u can)
The more you learn in Photoshop the more you realize how little you know
(in reply to Tony1M)
Post #: 14
RE: Twist Tie Fell Inside Spark Plug Hole! - 9/27/2008 10:55:16 AM
BU50
Status: offline
its been 3 days man... let us know what happened...
(in reply to Tippman7641)
Post #: 15
Honda Accord >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6827
sir_nasty6303
falkore245657
00accordlx5s3797
deserthonda3574
finch133254
jimblake3131
19accord973125
live2rice2627
smaglik2594
New Vendors
Sportwing
