WHAT IS THIS ABS LIGHT
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> WHAT IS THIS ABS LIGHT Page: [1] 2   next >   >>
Login
WHAT IS THIS ABS LIGHT - 11/10/2004 8:25:50 PM
shinobi16
Status: offline
I am the original owner of a 1994 ACCORD EX. It has 180,000 miles on it and today the ABS light came on for the first time. What does it mean and how can I disable it? Thanks.
Post #: 1
[Deleted] - 11/11/2004 3:49:36 PM
Deleted User
[Deleted by Admins]
(in reply to shinobi16)
  Post #: 2
RE: WHAT IS THIS ABS LIGHT - 11/16/2004 8:27:50 AM
RTexasF
Forum Monitor
Status: offline
RTexasF's photo gallery
That light is telling you that your anti-lock brake system is not working or is malfunctioning. Frankly I wouldn't just blow it off, I'd have it inspected soon by at least two different garages. The thought of stomping on the brakes without ABS and skidding into trouble is not appealing.
(in reply to Deleted User)
Post #: 3
RE: WHAT IS THIS ABS LIGHT - 11/22/2004 1:21:13 PM
poff1986
Status: offline
poff1986's photo gallery
MOST LIKELY ITS BECAUSE YOU HAVE A FAULTY WHEEL SPEED SENSOR. First check your brake fluid levels to make sure their not below the min. limit. it could set off the abs light. most likely its one of those two problems....good luck!
_____________________________
SOHC VTEC
(in reply to RTexasF)
Post #: 4
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 10:38:31 AM
Evlampius
Status: offline
quote:
ORIGINAL: poff1986
nah - brake fluid low will turn on the "brake" indicator and only after a while will turn on ABS light
it could be wheel sensor, but could be not..
(in reply to poff1986)
Post #: 5
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 12:15:40 PM
jayhova804
Status: offline
jayhova804's photo gallery
mine came on after i had a flat tire but since i got new tires the ABS light has not been on
BANNED
(in reply to Evlampius)
Post #: 6
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 12:49:10 PM
Evlampius
Status: offline
hey my car is so smart - if I lift it up in the air and try to run it - it will turn the ABS light on
so I went and plugged the computer to check the ABS code and it gave me code #xxx
and a message : WTF dude, my front wheels are running and rear wheels hold still - I'd better signal you with ABS light that something is wrong!!!
(in reply to jayhova804)
Post #: 7
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 5:19:46 PM
01hondaccordlx
Status: offline
i have a question with the ABS and SRS light. my friend david has a 97 and i know a couple people the have around about the year and they all had the 2 lights problem come on and it all drives the same. we put brake fluid in it, but have been to lazy to hook up to the OBD2 port and see. any ideas?
Post #: 8
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 5:44:05 PM
accordlowered04
Status: offline
accordlowered04's photo gallery
i have a 1996 accord and the only light that wont go off in my accord is the SRS. Does anyone know how i could get that to go off. I hooked it up to a machine and it didnt say anything. What could i do next?
1991 Honda Accord
www.animatedimages.org
(in reply to 01hondaccordlx)
Post #: 9
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 9:00:20 PM
Evlampius
Status: offline
turn the engine OFF and wait 10 seconds <--- you have to wait 10 seconds for the memory to reset.
you need SRS service connector - when you plug it to the Service check connector the one on the passenger side. Turn the ignition ON - the SRS indicator will come on for 6 seconds and go off. Then it will indicate the DTC code:
the DTC consists of a main code and a sub code and including the most recent problem up to three different mulfunctions can be indicated.
main code flashes are 1.2 seconds in duration while sub codes are short flashes of 0.3 sec. the delay between codes (main and sub is 2 seconds)
in case of intermittent failure the SRS light will indicate the DTC one time then it will stay ON
so read the code and tell me what it is
(in reply to accordlowered04)
Post #: 10
RE: WHAT IS THIS ABS LIGHT - 5/11/2005 11:29:01 PM
jayhova804
Status: offline
www.troublecodes.net.
this may help you also
BANNED
Post #: 11
RE: WHAT IS THIS ABS LIGHT - 5/12/2005 12:27:28 AM
Status: offline
Yo..Jayhova804...
That's a good site you put in there.
I went to it and did some exploration which was really good stuff.
Again..Thanks For The Lead Site
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
Post #: 12
RE: WHAT IS THIS ABS LIGHT - 5/12/2005 12:33:58 AM
jayhova804
Status: offline
im here to help im just glad i made a informative post lol
BANNED
(in reply to WheelBrokerAng)
Post #: 13
RE: WHAT IS THIS ABS LIGHT - 5/12/2005 9:04:52 PM
habeel
Status: offline
ive had the abs shut down for a while. think it was through severe abuse of the brakes. went a couple of days without it, amd then it fixed itself! the manual says its self checking. but to be honest i would like it gone. abs annoys me
Post #: 14
RE: WHAT IS THIS ABS LIGHT - 5/13/2005 3:39:22 PM
Evlampius
Status: offline
quote:
ORIGINAL: habeel
well then you need it checked and replace the part that is bad
(in reply to habeel)
Post #: 15
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6827
sir_nasty6303
falkore245650
00accordlx5s3797
deserthonda3574
finch133238
jimblake3131
19accord973125
live2rice2622
smaglik2594
New Vendors
Sportwing
