Water In Trunk ,,,,,FIX ,,,accord 90-97
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> Water In Trunk ,,,,,FIX ,,,accord 90-97 Page: [1]
Login
Water In Trunk ,,,,,FIX ,,,accord 90-97 - 5/12/2006 1:06:25 AM
deserthonda
Score: 0
Status: offline
The most common cause i have seen for water accumulating inside the trunk , is the outer tail lense gasket
these gasket are made of a foamy rubber material, over the years , they get hard and crack , when that happens , after a good downpour you might find water in the trunk..
replacing these gaskets is real simple
parts needed :2 gaskets, honda-bond or rtv silicone
90-93 accords,,part # 33503-sm4-003
94-97 accords,,part # 33503-sv4-ao1
you will need two ,they are the same for either side,,
tools needed : 1/4 inch 8 mm deep socket, small extension, rachet, i would not use anything bigger than 1/4 inch , a bit too much force and you might snap the stud in the lense
remove the panel covers, Disconnect the connectors that are plugged into the tail lense, remove the 8 mm nuts, remove tail lense,
Clean the area real good where the gasket will meet the body of the car, apply some honda-bond ( silicone ) where the gasket will meet the body, reinstall tail lense assembly..
DO NOT overtighten the 8 mm nuts as they will snap easily..plug the connectors back and you are done,
Always chk your work, make sure all the lites back there work properly..
_____________________________
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
Post #: 1
Page:   [1]
Honda Accord Forums >> General >> Do-It-Yourself Section
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6832
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133259
jimblake3136
19accord973125
live2rice2635
smaglik2594
New Vendors
Sportwing
