Which one?
  Printable Version
Honda Accord >> General >> Do-It-Yourself Section >> DIY Requests >> Which one? Page: [1]
Login
Which one? - 8/18/2008 2:43:33 PM
davisi
Score: 0
Status: offline
I have a 1998 Honda Accord EX-ULEV VTEC and I got an air breather filter to prevent the carbon emmisions from going back into my intake and I am not sure where to put it...Do I replace the PCV valve or the breather Hose??
Post #: 1
RE: Which one? - 8/19/2008 7:06:15 AM
falkore24
Score: 0
Status: offline
falkore24's photo gallery
It is supposed to replace the breather hose.  Realize that you are eliminating the PCV function by not having suction on the cylinder head.  Your mini-me filter is more likely to hold the oil in the valve cover gasket than filter any air going into there.  IMO, it''''s not a good idea to partially eliminate things.  You''''d be better off pulling the PCV valve and plugging the hole, but I wouldn''''t recommend that either.
EDIT:  I just re-read your post ..... carbon emissions???   From the valve cover????   There''s not really any exhaust in there ..... probably traces, but it''s basically hot oil-laden air in there.
< Message edited by falkore24 -- 8/19/2008 7:08:13 AM >
_____________________________
2006 Scion TC (ZPI-18G pending)
2000 V6-AT (RIP 3G)
Temp Search thanks to Finch13
(in reply to davisi)
Post #: 2
RE: Which one? - 8/19/2008 3:56:37 PM
davisi
Score: 0
Status: offline
Ok so it looks like I was a little mislead by the instructions originally given to me (that is what learning is about I guess).  You say that it is used to replace the Breather hose.  In this case, you must be suggesting that, if used, I should put it where the breather hose connects to the intake manifold (i can see why...B/C this would allow for cleaner air to be taken into the throttle housing which would allow a lesser carbon build-up in the throttle plate) and the plug where the hose went into my valve cover...This seems like this is what I need but I have one minor issue...there is not quite enough space...any ideas?
(in reply to falkore24)
Post #: 3
Page:   [1]
Honda Accord Forum >> General >> Do-It-Yourself Section >> DIY Requests
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6838
sir_nasty6303
falkore245663
00accordlx5s3797
deserthonda3574
finch133259
jimblake3137
19accord973125
live2rice2635
smaglik2594
New Vendors
Sportwing
