Wiring for Headlight LED's???
Login | |
Wiring for Headlight LED's??? - 4/28/2008 10:38:01 AM
98CoupeW/Carbon
I have the projector beam headlights with the LED BMW style rings and I need to know how to wire them up. The wires for the led's(red & Black) are seperate from the normal headlights and turn signals. can anyone give me some advice for the best way to wire these, currently I have them spliced directly into the headlight wires but I'd like to do it proper and I would like to wire them to a switch next to the cruise control button on the dash so I can turn them on and off at will. Thanks in advance for the suggestions
RE: Wiring for Headlight LED's??? - 4/28/2008 10:43:37 AM
finch13
I had mine spliced into my parking lights and they worked great. If you want them switched, create a new positive lead from the fuse panel, run a 1 amp inline fuse, then run it to the positive terminal on your switch, then connect the negative to any grounding point on the chassis. Same goes for the negative on the LED lead.
_____________________________
USE ME TO SEARCH HAF 99 Accord F23A1 5MT
RE: Wiring for Headlight LED's??? - 5/11/2008 1:12:01 PM
98CoupeW/Carbon
df
< Message edited by 98CoupeW/Carbon -- 5/13/2008 10:49:21 AM >
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
