ac diagnoses step by step
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> ac diagnoses step by step Page: [1] 2   next >   >>
Login
ac diagnoses step by step - 7/24/2008 11:34:15 AM
maro
Status: offline
Please explain to me like an infant. AC never worked. I want to fix it. Where do I begin?
_____________________________
1996 Accord Ex Coupe
Eucaliptus Green w/ pealing clear coat. eerrrrrr.
152,000
AEM SRI
Exedy Clutch
NGK irridiums (replacing with the regular NGKs soon)
Honda MTF
Post #: 1
RE: ac diagnoses step by step - 7/24/2008 12:53:19 PM
JimBlake
Status: offline
More information for us.
Are you comfortable with electrical troubleshooting & repair?  Thats the place to start.
Working with the refrigerant system means buying some expensive equipment.  More practical to fix (or rule out) electrical problems then take it to a shop.
How do you want to do this?  Theres a few people on here that are much better than me with the refrigerant side of things.
'03 Accord & '07 Civic
'01 Saab 9³ & '05 9²x
(in reply to maro)
Post #: 2
RE: ac diagnoses step by step - 7/24/2008 1:01:23 PM
falkore24
Status: offline
falkore24's photo gallery
Check that the fan and compressor clutch work first.
2006 Scion TC
Short Shifter
radiator panel
fully lit 3rd brake light
strut bar
4pt rear bar
sways
S-pipe
pulley
poly bushings
poly mounts
ETD
air horns
pending
ZPI turbo system
2000 V6-AT (RIP 3G
(in reply to JimBlake)
Post #: 3
RE: ac diagnoses step by step - 7/24/2008 1:01:50 PM
falkore24
Status: offline
I had a better post, but it got the HAF error.
2006 Scion TC
Short Shifter
radiator panel
strut bar
4pt rear bar
sways
S-pipe
pulley
poly bushings
poly mounts
ETD
air horns
pending
ZPI turbo system
2000 V6-AT (RIP 3G
(in reply to falkore24)
Post #: 4
RE: ac diagnoses step by step - 7/24/2008 1:17:11 PM
maro
Status: offline
I would just be searching old threads if it would work. How do I test the clutch? and I''m not expert at electric, but I can give it a shot (shock)!
< Message edited by maro -- 7/24/2008 1:18:29 PM >
152,000
AEM SRI
Exedy Clutch
Honda MTF
Post #: 5
RE: ac diagnoses step by step - 7/24/2008 1:22:54 PM
falkore24
Status: offline
Have someone sit in the car and turn the AC on and off, you should see the pulley engage and disengage the compressor.  With the car and AC on, both fans should spin.
2006 Scion TC
Short Shifter
radiator panel
strut bar
4pt rear bar
sways
S-pipe
pulley
poly bushings
poly mounts
ETD
air horns
pending
ZPI turbo system
2000 V6-AT (RIP 3G
(in reply to maro)
Post #: 6
RE: ac diagnoses step by step - 7/24/2008 1:58:10 PM
maro
Status: offline
okay, I''ll give it a shot in about an hour. If the clutch does not engage, what is it then a matter of?
152,000
AEM SRI
Exedy Clutch
Honda MTF
Post #: 7
RE: ac diagnoses step by step - 7/24/2008 2:38:57 PM
falkore24
Status: offline
bad clutch or controls
2006 Scion TC
Short Shifter
radiator panel
strut bar
4pt rear bar
sways
S-pipe
pulley
poly bushings
poly mounts
ETD
air horns
pending
ZPI turbo system
2000 V6-AT (RIP 3G
(in reply to maro)
Post #: 8
RE: ac diagnoses step by step - 7/24/2008 3:05:32 PM
JimBlake
Status: offline
Other possibilities...
Refrigerant leaked out = pressure switch prevents the compressor from switching on.  In that case you need to find & fix the leak.
Electrical problem = lots of possible places.  Bad relay, bad switch, loose wiring, etc, etc...
Post #: 9
RE: ac diagnoses step by step - 7/25/2008 9:04:31 AM
maro
Status: offline
okay,
I didn''t start diagnosing the ac yet.. gonna start tomorrow, had to take her in this morning for rotors and brakes.
I''ll be on here asking quetions this week-end for sure. Thanks guys
152,000
AEM SRI
Exedy Clutch
Honda MTF
Post #: 10
RE: ac diagnoses step by step - 7/25/2008 10:24:13 AM
falkore24
Status: offline
Just don''t get frustrated if you don''t get answers quickly.  Most of the members here are on when they are slacking off at work.  I''m rarely online during the weekend .... and I''m taking off Mon. and Tues.
2006 Scion TC
Short Shifter
radiator panel
strut bar
4pt rear bar
sways
S-pipe
pulley
poly bushings
poly mounts
ETD
air horns
pending
ZPI turbo system
2000 V6-AT (RIP 3G
(in reply to maro)
Post #: 11
RE: ac diagnoses step by step - 7/27/2008 7:12:41 AM
maro
Status: offline
Okay, so no fans come on And I hear nothing when engaged
Next step?
152,000
AEM SRI
Exedy Clutch
Honda MTF
(in reply to maro)
Post #: 12
RE: ac diagnoses step by step - 7/29/2008 8:12:09 AM
maro
Status: offline
up..
152,000
AEM SRI
Exedy Clutch
Honda MTF
(in reply to maro)
Post #: 13
RE: ac diagnoses step by step - 7/30/2008 6:42:18 AM
maro
Status: offline
so.... can anyone help me see through to the next step in diagnosing my ac
thanks guys
152,000
AEM SRI
Exedy Clutch
Honda MTF
(in reply to maro)
Post #: 14
RE: ac diagnoses step by step - 7/30/2008 7:48:07 AM
deserthonda
Status: offline
try an easy test, find the pressure switch  located rt side frt of car by the rec drier , unplug the connector, jump the 2 wires together  ( blue/yellow and red/white ) if fans and compressor engage  most likely system is out or very low on freon ,,,,,
if you have a set of gauges you can hook them up and chk the pressures
try this first and let us know
No Year No Model in Your signature
No Help from me
Take a look in the DIY section before asking for help
Always Diagnose First,,, Before Replacing Parts
(in reply to maro)
Post #: 15
Honda Accord >> General >> General Tech Help
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6559
sir_nasty6303
falkore244986
00accordlx5s3741
deserthonda3536
19accord973076
jimblake2920
smaglik2515
rtexasf2336
finch132089
New Vendors
Sportwing
