accord will not start
Login | |
accord will not start - 8/19/2008 9:46:45 AM
patrickz
hi, i have an 1996 honda accord 4 cyl. non vtec. i recently removed the fuel rail to clean off all of the corosion ang oil. i replace all of the o rings and gaskets on the injectors also. once i reinstalled everything, it will not start. the rail is getting pressure, and all hoses and connections and correct. i was wondering is anybody could help me out. Thanks, Patrickz
_____________________________
-it is what makes us different, that brings us together- 1996 accord 25th anniversary no vtec
RE: accord will not start - 8/19/2008 9:49:54 AM
Aquariumjunkie
have you checked the battery? if you have, then check the spark plugs, wires. does it turn over?
01 Accord EX Coupe... Tein Springs AEM Cold Air GReedy EVO2 Cat-Back Exhaust Strut Bar 10K HIDs
RE: accord will not start - 8/19/2008 9:55:10 AM
patrickz
yes, the battery is good, and the spark plug wires and good. the starter cranks the engine, but it wont turn over.
RE: accord will not start - 8/19/2008 10:05:37 AM
patrickz
yes, the battery is good, and so are the wires. it turns but wont start
RE: accord will not start - 8/19/2008 10:14:29 AM
PAhonda
You need to determine if the problem is lack of spark or fuel. Does the check engine light stay on, and have you checked for any codes? You should hear the fuel pump turn on while the check engine light is on (~ two seconds) when you turn the key to the II position. It is a faint whirling/buzzing sound that comes from the back seat/trunk area.
1995 Accord EX MT
RE: accord will not start - 8/19/2008 10:21:11 AM
patrickz
how do i determine that? yes, the engine light stays on. i checked, and i can hear the fuel pump in the back
RE: accord will not start - 8/19/2008 12:06:46 PM
falkore24
Pull out a spark plug and tape it to the engine for a solid ground. Have someone crank the car to see the spark strength ...... best done at dusk.
2006 Scion TC (ZPI-18G pending) 2000 V6-AT (RIP 3G) Temp Search thanks to Finch13
RE: accord will not start - 8/19/2008 12:21:16 PM
PAhonda
Follow the instructions in this link to get the error codes: http://www.dhost.info/accordinfo/howto/cel.html Use a thin paperclip to jump that service connector. Post the code on here.
1995 Accord EX MT
RE: accord will not start - 8/19/2008 12:23:28 PM
JimBlake
Pull that spark plug right after trying to start it. Then you can check for fuel in the cylinder. Having pressure in the fuel rail doesnt prove the injectors are firing.
'03 Accord & '07 Civic '01 Saab 9³ & '05 9²x
RE: accord will not start - 8/20/2008 10:27:42 AM
patrickz
ill try that and tell u how it goes. thank you so much.
RE: accord will not start - 8/20/2008 2:56:46 PM
PAhonda
That SRS code is for the passenger air bag and it is either (2-2, or 1-1) and will not cause your car not to start. That 16-pin connector behind the ash tray will hook up to any OBD code reader to pull off more detailed codes (P#### is how they are reported). Since your car isn''t running, you can''t drive it to autozone to get the codes read for free. It isn''t worth buying one, since a paperclip will also get the code for you. As long as you shorted the blue two-pin connector and NOT the one with three wires, then you found the right connector. If the check engine light didn''t flash any codes, then there are likely no codes stored on the ECU. I can''t remember what the check engine light does if no code is stored (either remains on, shuts off).
1995 Accord EX MT
RE: accord will not start - 8/20/2008 3:00:58 PM
patrickz
ok how do u recomend i get it read then? i went back through the engine today, and all connections are correct and secure to the best of my know how.
RE: accord will not start - 8/21/2008 5:40:22 AM
patrickz
then how can i find the codes?
RE: accord will not start - 8/21/2008 2:22:29 PM
PAhonda
If the CEL did not blink any codes when you had the connector shorted, then there are likely no codes stored on the ECU. I was hoping that something obvious would come up. Have you pulled a sparkplug and tested for adequate spark. Without this info, its hard to give you more detailed instructions.
1995 Accord EX MT
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
