aftermarket intakes arent good for your engine?
Login | |
RE: aftermarket intakes arent good for your engine? - 5/29/2006 11:46:30 PM
Joined: 8/30/2004 From: Canton/Massillon, Ohio 44646 Status: online
No! I've been running one for the last 284,000 miles and have not ever had a days problem with my motor taking a breath Some mechanics talk thru their (donkey's behind's)..... WheelBrokerAng
_____________________________
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
RE: aftermarket intakes arent good for your engine? - 5/29/2006 11:47:50 PM
thunder_x
Joined: 10/2/2005 From: southern california Status: offline
what kind of intake and air filter do you use?
RE: aftermarket intakes arent good for your engine? - 5/30/2006 12:19:24 AM
mbo1985
As long as the wet oil type filters have oil on them, they filter out fine. Stick with a brand name though, like K&N.
RE: aftermarket intakes arent good for your engine? - 5/30/2006 1:29:22 AM
**I just happen'd to use an OBX Cold Air Induction Intake System part #127-1601-1 Air Filter is by them also and is made for wet weather also, i think my gain is around 7 to 13 H.P. with their unit..** WheelBrokerAng quote:
ORIGINAL: thunder_x what kind of intake and air filter do you use?
RE: aftermarket intakes arent good for your engine? - 5/31/2006 3:13:21 AM
marbro
i dont think it has a cleaning kit but i dont have quicktime installed to watch the video ^_- http://trucks.aempower.com/dryflow_cleaning.asp
RE: aftermarket intakes arent good for your engine? - 5/31/2006 9:30:32 AM
RTexasF
Forum Monitor Posts: 2347
Joined: 11/16/2004 From: Brownsville, TX Status: offline
quote:
ORIGINAL: 19Accord97 Hey guys, sry to kinda jack the thread but I was wondering where I can buy the filter cleaning kit for an AEM Dryflow filter? Thanks:) There is a specific cleaning formula from AEM for this filter.......I have one too. They warn against using anything else but that may be crappola, I didn't want to chance it myself. It's shown on the video link above that marbro provided. I got mine from Sam@missionspeed.
< Message edited by RTexasF -- 5/31/2006 9:34:21 AM >
''''04 2.4l 5M EX Sedan Neuspeed short shift kit V-6 6 speed front strut/firewall brace 17mm rear anti sway bar AEM Shorty DC Sports SS Header Kicker Speakers JL Audio Clean Sweep JL Audio Amp 200W Bazooka sub V-6 OEM 7 spoke alloys
RE: aftermarket intakes arent good for your engine? - 5/31/2006 10:14:51 AM
YeuEmMaiMai
That guy's mechanic is right about aftermarket air filters. http://home.usadatanet.net/%7Ejbplock/ISO5011/SPICER.htm take a look at all of those charts particularly the ones that how much dirt was allowed to pass through the filter...
Jesus is Salvation White 2002 Acura CL type S. 68K and change Criminals thrive upon the intolerence of society''s understanding.....and political correctness
RE: aftermarket intakes arent good for your engine? - 5/31/2006 1:00:26 PM
RTexasF
quote:
ORIGINAL: YeuEmMaiMai That guy's mechanic is right about aftermarket air filters. http://home.usadatanet.net/%7Ejbplock/ISO5011/SPICER.htm take a look at all of those charts particularly the ones that how much dirt was allowed to pass through the filter... Some indeed do allow more dirt to enter but the REAL test is having your oil analyzed. High silicon levels are a sure sign of too much dirt passing through although other things could also cause it. I have seen oil analysis' with K&N cone filters that had LOWER silicon levels than with the OEM paper ones. There are too many variables for a blanket statement that "all aftermarket filters let more dirt through". That just isn't so.
< Message edited by RTexasF -- 6/13/2006 9:31:28 AM >
RE: aftermarket intakes arent good for your engine? - 5/31/2006 4:01:05 PM
YeuEmMaiMai
The reason I posted that test was it was controlled so that other factors such as vaccum leaks, etc are not taken into consideration. Some people live in areas where there is a lot more dirt than others, etc too many variables.. if an OEM filter is not properly installed, it is quite possible for the oil to be dirty...
