beautifully clean 87 dx manual fuel pump problem
Login | |
beautifully clean 87 dx manual fuel pump problem - 3/5/2007 4:01:06 PM
Hatchit
Score: 0 Joined: 3/5/2007 Status: offline
OK so i don't listen to my own advice and didn't run a capacitor while ruing 2 ten inch subs... so i blew my alternator... it sat in my garage for about 16 months and got sponge baths while i stared at my shinny unmovable car... replaced the alternator and HEY it's not starting... so i replaced the fuel pump cause i could hear it wasn't Turing on with the acc. key possition... the my friend who put it in says it's running but still no fuel is getting to the engen... so he thought he wired it back wards and told me to get under there drop everything again and switch the wires in the first accessible place... i did so... and now the pump wont even turn on in the acc. key position.... so i stopped touching the damn car so i wont Eph it up aymore.... and the dude thats supposed to be helping me is totally flaking on me... and she (the accord) is so close to running it hurts .... please can anyone give me some insight or a web site that may help.... in desperate need
< Message edited by Hatchit -- 3/5/2007 4:47:17 PM >
_____________________________
Hatchit...87 accord DX, hatch back (no auto seat belts)2nd ower, little wear-N-tare, CLEAN AS NEW(in 1987)
RE: beautifuly clean 87 dx manual fuel pump problem - 3/5/2007 4:12:13 PM
sir_nasty
Score: 0 Joined: 2/23/2006 Status: offline
Welcome to the forum! Sorry to hear about the issues, I know your pain, I just went through something similar with my 81 civic.... First things first, since I can't edit that post could you please remove the profanity from it? Now, The first thing I would do is check your fuses, then turn the key to the on position and see if you are getting power to the fuel pump, also make sure the fuel lines are connected properly to ensure proper fuel flow, if you have power back there, disconnect the outlet hose (going to the front of the car) and turn the key on, if it sprays fuel then you know the pump is fine, if not then we'll deal with that later.... If all your fuses are fine, and no power then locate your main relay/fuel pump cutoff and see if it's getting power from the ignition...
1981 Civic Station Wagon - ROhnda (Really Old Honda) 1981 Honda CB650 Motorcylce - WHEE What More can I say? 2000 Lexus RX 300 - Oooh baby my wife let me drive it once!! Quote: Life''s great but it''s not all beer and skittles
RE: beautifully clean 87 dx manual fuel pump problem - 3/5/2007 4:49:45 PM
Hatchit
ok... i cleaned up my message ad my frustration wot be expressed in explitives.... well i just ran into another problem.... my battery has been shot by the cold.... so i can't even trouble shoot right now... but i really want to thank you for the for this advice....i'll repost as so as it's charged or replaced
RE: beautifully clean 87 dx manual fuel pump problem - 3/5/2007 5:24:54 PM
sir_nasty
thanks for cleaning that up.... get a charger on that battery and you should be able to at least troubleshoot with the charger on there.... let us know how it goes (hopefully it doesn't take another 16 months to get to it *L*)
RE: beautifully clean 87 dx manual fuel pump problem - 3/5/2007 5:30:17 PM
Hatchit
fuses and relays are good... god i hope it dot take aother 16 months.... i need working in two weeks
RE: beautifully clean 87 dx manual fuel pump problem - 3/5/2007 5:54:26 PM
sir_nasty
run those tests and let us know what the results are
RE: beautifully clean 87 dx manual fuel pump problem - 3/5/2007 11:14:53 PM
Hatchit
battery on charge at auto zone... will run tests and up-date tomorrow... thank you again for the help
RE: beautifuly clean 87 dx manual fuel pump problem - 3/6/2007 12:06:21 AM
deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
quote:
ORIGINAL: sir_nasty .... First things first, since I can't edit that post could you please remove the profanity from it? Yo Nasty why cannot you edit the post ??? if car has been sitting for 16 months you have some bad gas,, i would drain the fuel tank, install some new gasoline,, also to see if you are getting gas at carb inlet hoe,, remove the hose from the carb and have someone crank the engine,, put a can under the hose so gas if it comes out will not go all over the place ,, if no gas comes out, either pump not working or possible plugged fuel filter the one by the fuel tank.. if fuel comes out take a good look at it .. see if it looks normal or looks and smells like terpantine .. let us know
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: beautifuly clean 87 dx manual fuel pump problem - 3/6/2007 11:30:13 AM
Hatchit
definitly bad gas.... when i replaced the fuel pump (the one inside the tank) i cleaned out all bad gas... ad swished some rubbbig aclohol to get rid of any rust i couldn't see. and other then the dirty gas it was a very clean tank.... but that was before i rewired it... plus yesterday when i disasembled the gas tank again... there was new fuel up to the fuel line, right utill the line goes back into the frame of the car...(you know at the swishy fuel line plug)so now im thinking that it was working the whole time.... but that line from the frame up(to the engin) is cloged some where.... and being in-side the frame, is there any way i can pressure the line and sqweez it out??? or will that cause the old line to POP like a balloonn??
RE: beautifuly clean 87 dx manual fuel pump problem - 3/6/2007 12:01:06 PM
Hatchit
oh and with the presure i was getting fuel wasnn't even makin it out throught the firewall... so some where between the fire wall and the spot it comes out of the frameis where it is clogged... im sure thats my problem now.... i just eed to know i safe cheap way of unclogging that line...any one have a good idea??? plus i installed a after market fuel filter whe the car was runig 16 months ago.... it's a cheap clear plastic feul filter, ad was put in the lie as soon as it leaves thefire wall....was this a good idea or bad idea to put another filter on the line???
RE: beautifuly clean 87 dx manual fuel pump problem - 3/6/2007 12:14:46 PM
Hatchit
oh and is it true that my fuel pump my keep running if it does not feel preusure???? i had pressure and that why it stopped ... but i wated to check with you all beacause i was told that it was good that it was clogged for now ... cuz if it wasnt my fuel pump would continue to pump untill it felt the presure? or utill it burned out...
RE: beautifuly clean 87 dx manual fuel pump problem - 3/6/2007 12:47:54 PM
sir_nasty
Desert: I can't edit posts or manage in the DIY section at all, I think only you can.... The plugged line theory is why I said pull the line at the fuel pump and see if it pumps, then reconnect it and check it at the firewall again, if it's not working at the firewall then you've got a plugged line for sure and not a bad fuel pump, if it's not cold enough out to freeze any water that was possibly in the line then you can try blowing out the line with an air compressor, if you suspect a frozen line use a small funnel and pour a little beat of heat (fuel treatment) stuff down the line and let it sit for an hour or two then blow it out with an aircompressor.... when the fuel pump kicks on it will run until the line is pressurized, if you've got the line off it's just going to keep pumping until you turn the key off.... the other fuel filter (as long as it's installed properly) should be fine...
RE: beautifuly clean 87 dx manual fuel pump problem - 3/6/2007 1:02:58 PM
Hatchit
well this blows... all 5 batterys i took in to see if any of them could even hold a charge.... all but one are bad... and apparently i broke the only good one.... so this maybe comin sense to everone else... but to thoughs who dont know.....be careful with you car's battery( side post batterys ) if you tighten them down too much you will snap the inner connection with the wired bolt peice.... so make sure it's not lose but do not tighten it too much.... or you'll have to buy another new battery like me... will be on often to check my other questions but will up date you on the car wen i get paid and get a NEW battery
RE: beautifuly clean 87 dx manual fuel pump problem - 3/7/2007 11:48:57 AM
Hatchit
ok so i have been told to wait on presurizing that hose untill i do a stupid's check list... like make sure the filter wast replaced in back wards(sese it only allows one way passage)... but just icase im borrowing an air compressor today... as well as getting a ew battery today so.... up-dates soon.... ty so much for your help guys...reposting soon
RE: beautifuly clean 87 dx manual fuel pump problem - 3/8/2007 11:42:30 AM
Hatchit
got good news... no clogged line so,i gess, im back at square 1.... still waiting for the funds ona new battery....
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
