change your tranny fluid
  Printable Version
Honda Accord Forums >> General >> General Tech Help >> change your tranny fluid Page: [1] 2 3   next >   >>
Login
change your tranny fluid - 3/29/2006 11:20:02 PM
Green_Accord
Status: offline
Has anyone ever tried to change their tranny fluid? Is it hard to do ..?
Post #: 1
RE: change your tranny fluid - 3/29/2006 11:27:00 PM
98accrd
Status: offline
It's easier than changing engine oil.
(in reply to Green_Accord)
Post #: 2
RE: change your tranny fluid - 3/30/2006 9:11:00 AM
meazz1
Status: offline
I just did it on my 94 accord last weekend and it so easy. Make sure you also change the Plug washer and use Honda fluid.
The drain plug is by the side of front pass. side wheel.
Very simple.
(in reply to 98accrd)
Post #: 3
RE: change your tranny fluid - 3/30/2006 9:31:30 AM
accorddriverc
Status: offline
accorddriverc's photo gallery
I've never done it myself. I let the place that changes my oil do the tranny fluid
_____________________________
2000 Accord EX(R.I.P. 5-2-06)
1999 Civic LX
(in reply to meazz1)
Post #: 4
RE: change your tranny fluid - 3/30/2006 11:11:08 PM
deserthonda
Status: offline
quote:
ORIGINAL: Green_Accord
what year ?? auto or manual ??
Post #: 5
RE: change your tranny fluid - 3/31/2006 12:54:11 AM
Status: offline
Hey Deserthonda..at least we know it's Green...
quote:
ORIGINAL: deserthonda
" Prejudice Saves Time ; It Enables Us To Form Opinions Without Facts "
(in reply to deserthonda)
Post #: 6
RE: change your tranny fluid - 3/31/2006 7:30:31 PM
Green_Accord
Status: offline
d'oh my bad .. it's 2000 V6 with auto tranny.. thanks
(in reply to WheelBrokerAng)
Post #: 7
RE: change your tranny fluid - 3/31/2006 7:53:54 PM
Markus26
Status: offline
piece of cake, theres a drain bolt on the side of the tranny. 3/8" drive fits right into it, fill through the dipstick. 3qts Honda ATF-Z1
Post #: 8
RE: change your tranny fluid - 3/31/2006 9:00:45 PM
Green_Accord
Status: offline
thanks so much .. i'll try it tomorrow..
(in reply to Markus26)
Post #: 9
RE: change your tranny fluid - 4/1/2006 6:54:04 PM
Lance Link
Status: offline
shouldn't you flush the trans fluid and not bother with drain and fill?
Post #: 10
RE: change your tranny fluid - 4/3/2006 8:04:55 PM
Green_Accord
Status: offline
i cant cause i dont have the proper tool and those Jippy Lube charges up to $99 to flush which is not much different from drain and refill but just more expensive.. i'd love to work on my car so i prefer to drain and refill. Besides, it'll save me about $70 by doing that
(in reply to Lance Link)
Post #: 11
RE: change your tranny fluid - 4/3/2006 9:22:53 PM
mbo1985
Status: offline
you can flush it by taking off one of the hoses that goes to the radiator. Make sure you know what you're doing before you do this, but you can flush out every drop in that transmission if you do it right. If you're not careful, you'll have a messy driveway or worse! This is how I would do a trans fluid change for an auto:
Drain the pan and refill (install a new filter if needed). Then take off the radiator feed line and connect a suitable hose and run it into a 5 gallon bucket. Start the car and let the fluid drain out into the bucket untill the new fluid runs out. You can tell by the rich color of the new fluid verses the dirty color of the old. Then refill the fluid to the proper level. That's how I've been doing it anyways. This method works best with 2 people.
If you're not sure about doing it this way, then don't worry about it, but by doing it this you get all the fluid that's in the torque converter. Make sure you have plenty of new tranny fluid before you get going!
Post #: 12
RE: change your tranny fluid - 4/6/2006 12:15:18 AM
dj guest one
Status: offline
the plug is right under the tranny, remove plug and drain, there's no filter. Use a long funnel to refill. make sure you use proper oil!
Post #: 13
RE: change your tranny fluid - 4/9/2006 12:14:57 AM
nixalot
Status: offline
Would this be the same for a '98 4cyl automatic with the VTEC?
(in reply to dj guest one)
Post #: 14
RE: change your tranny fluid - 4/9/2006 3:48:49 AM
deserthonda
Status: offline
all honda tranny fluid is the same for all accords ...ATF-Z1
(in reply to nixalot)
Post #: 15
Jump to:
Featured Sponsors
Advertising Info
Top 10 Posters
wheelbrokera6766
sir_nasty6303
falkore245545
00accordlx5s3797
deserthonda3568
19accord973117
jimblake3082
finch133007
smaglik2594
live2rice2408
New Vendors
Sportwing
