dash lights not working
Login | |
dash lights not working - 4/27/2008 3:07:18 PM
bbcobra
Score: 0 Joined: 4/17/2008 Status: offline
I've been searching this subject for a couple of weeks now. I have a 99 accord ex. the dash lights and ac control lights are not working. I did the check on the dimmer found on one of the threads. It reads from 0 to around 19+ ohms. I have replaced the drivers side multiplex controller and the instrument cluster (junk yard parts). No difference. What else could cause this problem. I've also checked the fuses. thanks
RE: dash lights not working - 4/28/2008 8:53:12 AM
bbcobra
hello, any help out there?
RE: dash lights not working - 4/30/2008 9:40:41 PM
finch13
Score: 0 Joined: 6/7/2007 From: St. Paul, MN Status: offline
Sorry, I don't have any advice to offer, but try posting in the electronics section and you might get better results.
_____________________________
-> USE ME TO SEARCH HAF <- 1999 Accord LX F23A1 5MT
RE: dash lights not working - 5/1/2008 9:03:31 AM
bbcobra
thanks, I'll do that.
99 Accord EX Sedan, 4cyl VTEC, 5spd
RE: dash lights not working - 5/1/2008 9:40:59 PM
deserthonda
Score: 0 Joined: 12/3/2005 Status: offline
Ok lets see if we can fix this ... First of all did you chk the fuses ?? Underdash driver side fuse # 9 7.5 amps Underdash pass side fuse # 10 10 amps If fuses are bad replace and recheck If fuses are ok.. Rt side under dash by the kick panel , there is the taillight relay , it has 4 wires ,( 2 red/green, 1 red/yellow and 1 red/black.. with the headlite switch on, you should have power at both red/green .. ground at the red/yellow and power at the red/black if you have power at both red/green, ground at red/yellow and no power at red/blck ,, you got a bad relay.. it you got all the proper power and ground at relay, than you got a wiring issue from relay on,, A quick test is to give power to the red/black wire with head lite switch off ,, if dash lites wotk than you know the the wiring from relay downward is all good .. but chk the easy things first ( FUSES) ,,
No Year No Model in Your signature No Help from me Take a look in the DIY section before asking for help Always Diagnose First,,, Before Replacing Parts
RE: dash lights not working - 5/2/2008 8:15:58 AM
bbcobra
hey thanks, that's alot of help.
RE: dash lights not working - 5/3/2008 7:28:25 PM
bbcobra
ok, the fuses are good. I already checked these including the fuses under the hood. I can't seem to locate the relay though. All I can find under the dash on the right side is the connectors for the ac / heater unit. I'll keep looking. I even looked behind the kick panel, nothing there either. thanks for the help
RE: dash lights not working - 5/8/2008 5:17:35 AM
bbcobra
can anybody point me in the right direction to find the relay. I dont see one on the passenger side. Is it near or behind the fuse box?
Today's Posts
Most Active Topics
Make A Donation
Forum Rules & FAQ
RSS Feeds
Honda Accord Prices
Advertising Info
Contact Us |
Advertising |
Automotive Links |
Archive |
About Us |
Honda Accord Links |
Legal |
Privacy Policy |
© Honda Accord Forum.com
