2016 Sport, which headlight bulbs to match fog lights?
Old 04-02-2016, 11:41 AM
Thanks. I'll contact kensun. Hopefully they don't give me any trouble and say i need to buy a relay...
  #42
Old 04-02-2016, 11:49 AM
Kensun should be a good brand. You can use a relay also if you want to try that . I'm using a 35w 5500k ultra hid from Ddm and it was just plug and play. I do recommended getting an AC ballast and not the DC ballast. Not sure what the Kensun uses. You can search on YouTube why AC is better than the DC .
  #43
Old 04-02-2016, 11:48 PM
I have a 2016 sport and I installed the Kensun 5000k 35w and 1 of the lights won't stay lit at first. I have to flicker the lights on and off a couple times to get it to light. Would a relay harness correct this issue?
Thanks!
A relay harness might help and I would recommend one regardless as it will ensure your HID ballasts get sufficient power consistently. If the issue still occurs with a harness then you'll have to troubleshoot each component to determine the issue unfortunately.
I had the exact same symptoms with the TRS 50W HID kit, and after a ton of troubleshooting including using 2 separate relay harnesses and ruling out ballast and igniter defects, it turned out to be a defective bulb.
  #44
Old 04-05-2016, 12:40 PM
I contacted Kensun and told him the issue and first words out of his mouth were "You have a defective bulb." They are sending me a replacement bulb...
Thanks for the help.
  #45
Old 04-11-2016, 12:11 PM
Default 2016 ex-l
Please let me know what bulb size should I get for a HID kit for my 2016 Coupe EX-L.
I think it is H11 but just want to confirm with someone that has already changed the horrible halogen lights the car comes with.
I haven't seen posts about also replacing the high beams with HID lights.
Please let me know if it is possible to replace both the low and high beams.
If I buy the kit from Xenon Depot what option should I get with the lights? with
CANbus or Mopar?
Thanks for your help
  #46
Old 04-29-2016, 10:30 PM
Default 2016 Accord EX-L HID Installation Problems
Hello all, I am new to the forum. I purchased an HID kit for my accord and I am having trouble installing them. There is not enough space for me to get the bulb out and mount the ballast. Is there a simple way to make room in there? What needs to come out to make room? Any help would be greatly appreciated. Thanks.
  #47
Old 05-04-2016, 09:31 AM
Here is my lighting set up
Low beam: Morimoto 50w ballast + 6500K HID
Turn signal: switchback LED from superbrightled
Attached Thumbnails 2016 Sport, which headlight bulbs to match fog lights?-img_1609_zpsodszk3x3.jpg   2016 Sport, which headlight bulbs to match fog lights?-img_1576_zpswcxcfy2m.jpg   2016 Sport, which headlight bulbs to match fog lights?-img_1573_zps6ifx6xmt.jpg   2016 Sport, which headlight bulbs to match fog lights?-img_1570_zpslqzqalf0.jpg
  #48
Old 08-25-2016, 04:22 AM
Default 2016 accord sport
Sweet jesus you're headlight setup is very nice!
I've been looking for answers and it seems like you've got'em. What's your set up?
Spare me the struggle
Would you kind sir?!
  #49
Old 09-15-2016, 03:46 PM
serum02
02-14-2016 08:01 PM
Mattc941
01-18-2016 11:46 AM
Brenton Thornicroft
01-01-2014 01:33 PM
rob3201
02-07-2007 06:37 AM
Ntegra
10-09-2006 12:37 AM
Quick Reply: 2016 Sport, which headlight bulbs to match fog lights?
