REMOVING REAR DOOR PANEL 90 ACCORD
I have it most undone. I have pull from the bottom aND popped all the plastic clips, I have removed the screw from the arm rest and the one in the door handle LATCH? cup. The whole panel seems to loose I can move/rock it but it seems to be attached rgiht behind the door latch mechanism. Any ideas???
THANKS!!!
THANKS!!!
RE: REMOVING REAR DOOR PANEL 90 ACCORD
did you remove the pin that goes from right behind the inside door handle to a little clip? The handle should be surronded by a plastic piece that can be removed but wont come all the way out because of that pin. Its like a steel horizontal rod and you should just pop it out.
........_________
.......I...............I
......Handle
Ignore the dots, but behind the handle mounting piece there is a rod from the handle to another clip, (mine was pink)
........_________
......Handle
