instructions on removing door panel
Old 07-05-2008, 01:44 PM
pham9006's Avatar
Default instructions on removing door panel
does anybody have any step by step instructions. Im trying to get to my actuator.
Old 07-07-2008, 04:38 PM
t00fatt's Avatar
Default RE: instructions on removing door panel
Remove the two screws behind the plastic door that is behind the inside door handle. Then starting at the bottom left of the door panel, pry the panel from the door making your way all the way around releasing all the clips. Then lift the panel up and off the door, and disconnect the cable going to the inside handle, be careful not the brake the clip. Its pretty simple just be gentle and if you feel resistance you may have missed a clip. I hope this helps!
Jaretr1
05-02-2013 10:12 AM
New2JDM
04-01-2012 07:53 PM
mergliaa
01-10-2009 05:45 PM
gtchen66
08-17-2007 12:05 AM
RBG
09-28-2006 07:06 PM
Quick Reply: instructions on removing door panel
