Honda Electrical Load Detection (ELD) Bypass
#131
eh, i've been too busy to even work on my own car. mine now has 8,300 miles in under 3 months.
i'm getting ready to put an amp in and will then be motivated to test and evaluate the alternator bypass.
#133
After many searches, I keep coming back to this thread as being the most beneficial. I am having the same issue on a 1990 Accord EX, however, I have not properly identified the ELD on this car yet. I am 90% sure I have found it, but no dice yet. I have two photos below that I have taken with my cell phone. Sectioned in red on the second is what I "think" is the ELD, there is a small connector with 3 conductions; green/red, black/yellow, black. The colors coordinate with your write up, also, on a cold start I am seeing 14.5V at my rear battery and measuring 14.55v up front at the alternator. The DC voltage between the green/red and black at idle is about 2.49V. These factors lead me to believe that I have found the ELD, yet my OEM honda manual (the real shop manual) does not depict the ELD anywhere, so I am still guessing.
Also, hopefully I will be able to write up a dual alternator installation for this car soon. This is my dedicated SPL car, and we cannot having any voltage drops... I have already had it drop to 12.5v on me many times while playing music at full tilt, which was I was not enthusiastic about, and I hate having to have the a/c blower motor on the low speed in order to draw enough current to have the ELD excite the alternator.
Also, keephopealive, what audio forums are you on? I have seen your user name somewhere, diyaudio, caraudioclassifieds, or another. I cannot remember at this time.
#135
Exactly what I was hoping to hear, thank you for your swift response!
#136
I am on 6 other forums that i am active on and registered for probably a dozen more. I am the only one using "keep_hope_alive" all are audio or car audio based. mobileaudioforum, caraudio, driveaccord, caraudiojunkies, diyma, sounddomain, phoenixphorums, diyaudio, mobilesoundscienceforum, clubsciontc, smd, and others i don't have shortcuts for.
#140
I'd love to have this little black box, but until there is enough demand and the car is older, I don't see it happening. It's $$$$ and time in R&D to figure out how to get a beefier alt to run on the newer accords without any issues with the ECU. Does anyone know what all companies in addition to Rush are working on it?
