Ipod adapter question
#22
I had a few minutes to kill during lunch today so I started taking apart the dash to see how hard it is. I removed everything I need to except the cubby and only dropped two metal clips into the well (which I recovered). I can tell that I will need a magnetic screwdriver to put everything back together, but I'm confident now that i can do the install on my own.
I wonder if I'll ever figure out where the metal clips came from so I can put them back in the right spots...
I hope the part is delivered early!
#24
I guess while I have everything open I should replace the light bulb for the passenger's heated seat which is burnt out.
#26
At least I don't have traction control so there is no light there to go out. I do have a moonroof, although I can't picture in my mind where there are any lights for it.
#29
See:
Replacing the light bulb that lights up the heated seat button - Acura TSX Club : Acura TSX Forum
and
VSA/Moonroof/Seat Heater/Gear Shift Lights Replacement - Acura TSX Club : Acura TSX Forum
The second link has pictures, etc. Both threads also mention that if you don't mind cutting the extra wire, you can save a few bucks by getting the bulbs at radio shack instead of OEM.
#30
I found some amazing instructions on how to install the bulbs over at an acura forum since they use the exact same part.
See:
and
See:
and
