Rating on Foglight switch
Old 07-31-2007, 11:17 AM
ybier1
Default Rating on Foglight switch
Does anyone know what the rating is on the supplementary switch that comes along with the fog light kit on the 07 Accord Coupe?
Old 07-31-2007, 11:31 AM
sir_nasty's Avatar
Default RE: Rating on Foglight switch
Which rating are you looking for? Voltage handling? Amps?
Old 07-31-2007, 11:42 AM
ybier1
To tell you the truth, I was wondering on whether I would be able to use it as a rocker switch to control a Whelen Strobe power supply rated at 9 Amps. Not sure if your familiar with the supply console.....heres a link
http://www.highcomsecurity.com/emerg...-supplies.html
CSP690 Electrical & Physical Data:
[ul][*]Input Voltage: 12 volts (24 volts optional)[*]Input Current: 9.4 amps[*]InputPower: 120 watts[*]Total Output Energy: 36 joules[*]Dimensions: 2 1/2" (64mm) h x 5 7/8" (149mm) w x 6 3/4" (170mm) d[*]Weight: 2 lbs (0.9kg)[/ul]
Old 07-31-2007, 12:11 PM
sir_nasty's Avatar
The easiest way to figure that out would be look at your fuse box to see what size fuse honda runs for it's fog lights, if it was less than 10 amps I'd be stunned
Old 07-31-2007, 12:29 PM
ybier1
Thanks....its a 20A fuse.....Is there a way to figure out which pin is what?
Old 07-31-2007, 12:44 PM
sir_nasty's Avatar
The easiest way to determine which is what (I'm assuming you are talking about power vs. ground etc.) is with a volt meter or a test light.... Test lights are cheap/VERY easy to use
Old 07-31-2007, 12:46 PM
ybier1
thanks....ill give it a shot....
ryde
08-31-2009 02:17 AM
fall50
06-27-2009 02:55 PM
jsredlineracer
04-17-2009 06:59 AM
kaiotes
06-12-2007 12:31 PM
HondaRacer4Vtec
10-10-2006 11:54 AM
Quick Reply: Rating on Foglight switch
