Steering Wheel Controls
I have a 98 accord that didn't have steering wheel controls. I bought a control unit on Ebay and it only needs two wires but I'm not sure where to terminate on the stereo end.
The stereo model is 39100-584-A200.
Thanks
Thanks
Vehicle: Honda
All models
1998-2005
1. SWI wire color: White
2. Connector:
3. Notes: <li class="smallText"> Read the note in the chart below. These are the notes found in your instructions (note # 11) included with your SWI-JACK . Connect the INTERFACE's white wires to Pin 3 (normally Green/Red) of the above connector. If there is a wire (normally brown) in Pin 11 it will need to go to chassis ground.
Note #11 - ***THIS NOTE IS ONLY APPLICABLE FOR VEHICLES THAT ARE EQUIPPED WITH "Mode" BUTTON ON THE STEERING WHEEL THAT IS NOT ABLE TO BE PROGRAMMED BY THE SWI MODULE:***
Program the module for version 9. Cut the purple loop then connect one end of a 560 ohm resistor to the second (inside) purple wire, and connect the other end of resistor to the white wire. Insulate the first (outside edge) purple wire as it will not be used.
In Pre-2006 Vehicles without a mode button, if the resting (when no buttons are pressed) voltage on the white wire is 4.6 volts or less it may be necessary to program the interface for version 9 and cut the purple loop. Connect a 47 ohm and 150 ohm resistor ( included in packaging) in series. Connect one end of the resistors to the second (inside) purple wire, and connect the other end of resistors to the white wire. Insulate the first (outside edge) purple wire as it will not be used.
4. Version: Program SWI for version 3. 5. Programming: Proceed with normal programming.
All models
1998-2005
2. Connector:
sorry for the delay, my manual didn't have the steering wheel control wires identified. i figured i'd verify on mine today. then i remembered the instructions for an interface.
programming instructions for the pac-audio SWI-Jack are shown above. i've installed these before using their instructions and it worked great.
my car is torn apart right now, so i have no problem verifying the wire colors when i go back out. we have the same car and i have steering wheel controls. i need to get an SWI-Jack for my new HU. i sold mine a few years back.
I apologize for the stupid question but it looks like I need a module for the Steering Wheel Interface? I have the 3 button unit that mounts to the steering wheel but that's it. Another question is; what pins on the back of the stereo can I tap into to hook up a female jack for my phone to connect to?
Thanks
Thanks
Sorry, I had a crazy couple of days, on the road. Should be able to pull the controldoff and take pics for you.
You don't need a module, but the module above has instructions. We will see if they are any good. Thanks for your patience.
