DIY Answers. This section is for the staff of HAF to post detailed DIYs in response to the requests by the members.
94-97 EGR Ports Cleaned
Old 10-07-2009, 08:27 AM
hondadude's Avatar
Default 94-97 EGR Ports Cleaned
Here's a link;
http://www.freewebs.com/hondadude/95...5AccordEGR.htm
Old 07-02-2011, 11:42 PM
You can search d8N-SE047VY on YouTube for a good video.
Old 07-03-2011, 01:13 AM
Peli's Avatar
That is one of the best instructionals I've found online. And B12 is the best IMHO.
EricTheCarGuy has a great video on it too. We aren't supposed to have direct links. Removed the link, because that is the video I referenced above - PaHonda
And don't forget there's a bleeding bolt on the end of the fuel rail you can loosen/remove so you don't have to worry about spritzing fuel all over your engine. Circled in red. Just take that bolt off and put a rag under it while you work on the other disassembly, when I did this it just start drooling fuel whenever it wanted to until it was empty. Just don't pop out the injectors until you open that up and relieve some pressure.
Old 08-17-2012, 07:17 PM
firefighter44's Avatar
Almost A Senior Member
the link has stopped working
Old 08-17-2012, 08:26 PM
Here some new links:
"http://www.freewebs.com/hondadude/95%20Accord%20EGR/95AccordEGR.htm"
Copy and paste the above link without the quotation marks (" ").
http://home.comcast.net/~em-engineering/T2T013.pdf
Old 05-16-2014, 07:13 PM
link still doesn't work
Old 05-16-2014, 07:48 PM
Due to the dead links, here are the PDFs uploaded from the internet archives.
File Type: pdf
File Type: pdf
rykertest
07-14-2012 09:44 AM
Brokenaccord
01-14-2010 07:05 AM
jimbrown618
06-21-2007 08:30 PM
deserthonda
06-21-2006 05:18 AM
deserthonda
05-01-2006 05:05 PM
Quick Reply: 94-97 EGR Ports Cleaned
