Go Back   Honda Accord Forum - Honda Accord Enthusiast Forums > General > Do-It-Yourself Section > DIY Answers.
Sign in using an external account
Register Forgot Password?
Search
Welcome to the Honda Accord Forum - Honda Accord Enthusiast Forums.
If this is your first visit, be sure to check out the FAQ by clicking the link above. You may have to register before you can post: click the register link above to proceed. To start viewing messages, select the forum that you want to visit from the selection below.
Reply
LinkBack Thread Tools Search this Thread
Old 09-09-2011, 10:24 AM
Default How To Bleed the Power Steering System on a '04 Accord
Hello Accord peeps,
For those who own a seventh generation Accord and are experiencing increased steering effort as well as a pronounced noise when turning your steering wheel, it is very plausible that you need to bleed the power steering system. Here is the proper procedure for performing this simple maintenance job:
Note: Check the reservoir at regular intervals, and add the recommended fluid as necessary. Always use Honda Power Steering Fluid. Using any other type of power steering fluid or automatic transmission fluid can cause increased wear and poor steering in cold weather.
Note: If the fluid is contaminated, the screen in the reservoir may be partially blocked. Replace the reservoir if necessary.
1) Remove the reservoir from its holder. Raise the reservoir, then disconnect the return hose to drain the reservoir (refer to this Accord Power Steering diagram). Take care not to spill the fluid on the body and parts. Wipe off any spilled fluid at once.
2) Connect a hose of suitable diameter to the disconnected return hose, and put the hose end in a suitable container.
3) Start the engine, let it run at idle, and turn the steering wheel from lock-to-lock several times. When fluid stops running out of the hose, shut off the engine. Discard the fluid.
4) Reinstall the return hose on the reservoir.
5) Fill the reservoir to the upper level line.
6) Start the engine and run it at fast idle, then turn the steering from lock-to-lock several times to bleed air from the system.
7) Recheck the fluid level and add some if necessary. Do not fill the reservoir beyond the upper level line. If the fluid is contaminated, dark, or discolored, repeat the procedure as necessary.
This ad is not displayed to registered members.
Register your free account today and become a member on Honda Accord Forum!
Old 09-09-2011, 08:28 PM
www.patriotfiles.org WheelBrokerAng TheWheelBroker Retired Now
Send a message via AIM to WheelBrokerAng Send a message via Yahoo to WheelBrokerAng Send a message via Skype™ to WheelBrokerAng
Good post member...Thank You!
__________________
www.worldtradecenter.com
Turn Up Your Speakers ! Click on link
Reply
Tags
04, accord, accordsteering, air, bleed, bleeding, honda, hose, lock, power, reservoir, return, steering, system, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Advertising
Featured Sponsors
Vendor Directory
Our Sponsors
© Internet Brands, Inc.
Powered by vBulletin® Version 3.8.7
Copyright ©2000 - 2013, vBulletin Solutions, Inc.
SEO by vBSEO ©2010, Crawlability, Inc.
Honda and the Honda marquee are registered trademarks of the American Honda Motor Company, Inc. Neither American Honda Motor Company nor its subsidiaries or affiliates shall bear any responsibility for HondaAccordforum.com content, comments, or advertising. HondaAccordforum.com is not affiliated with American Honda Motor Company in any way. American Honda Motor Company does not sponsor, support, or endorse HondaAccordforum.com in any way. Copyright/trademark/sales mark infringements are not intended or implied.
Emails Backup
