Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
2008 - 2012 Maintenance Guide - 4 cylinder
Old 07-08-2012, 10:40 PM
Default 2008 - 2012 Maintenance Guide - 4 cylinder
This was created by one of our members Paul79UF and was included in one of his threads. Thanks Paul!
Honda Accord Maintenance Guide
Old 10-13-2014, 08:53 AM
Must say this is one of the best forums I have visited in a long time. Admins have made it quite clear they care about organizing info into easy to find digest. Just sayin'
Old 10-13-2014, 10:23 AM
Thumbs up Thanks For The Props
We do try to keep it organized for everyone...makes it so much easier to find what your looking for here in the forums.
By the way member, are you from Tampa?
Old 10-13-2014, 11:47 AM
lucky61's Avatar
Could this also apply to the 2007 accords with 2.4 engines and brakes??
Old 10-13-2014, 11:56 AM
Some of the procedures are the same. The K24 engine block is basically the same. Things like PCV valve, spark plugs, engine oil, etc. are the same.
2008, 2009, and just a few early production 2010 Accord came with rear pads that wore fast, Honda revised the brake pad compound, added V-springs, and had instructions to switch around the upper and lower rear caliper slide pins (that would not be applicable to the 2007).
Old 10-13-2014, 04:44 PM
lucky61's Avatar
Thanks for the info redbull-1..good to know.Was a bit concerned that those issues(brakes) would be applicable to the 2007 accord..a bit more relaxed now...
WICKEDPHOTO
North East
02-16-2012 02:33 PM
Reboticon
08-24-2010 06:50 AM
Paul79UF
DIY Answers.
07-26-2010 09:57 AM
StockRocket
01-30-2007 05:40 PM
Quick Reply: 2008 - 2012 Maintenance Guide - 4 cylinder
