Diagnose Brake Pedal Goes To Floor - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 07-29-2006, 03:07 AM
deserthonda's Avatar
Default Diagnose Brake Pedal Goes To Floor
IF the brake pedal goes to the floor ALL TTHE TIME ........you need to chk for external leaks,,
calipers, brake hoses, wheel cylinders, ( drum brakes ) brake lines, proportioning valve, or outer rear seal in the brake master cylinder making fluid drip all over the brake booster , when there is an external leak the brake fluid in the brake cylinder reservoir will be low or empty ..
NOW......... If the brake pedal GOES TO FLOOR INTERMITTENTLY ..............You need to replace the BRAKE MASTER CYLINDER .......it leaks internally and you will not see any fluid drop anywhere and fluid will not get low ........
IF it has an internal leak and when a shop looks at it they cannot find any leaks,, it will act up worse on HOT days and during the hottest part of the day,,,,,,,,,it might work ok in the early mornings and in the evenings,,,,,,,,,,
It is very very dangerous the way it is, because if you were to need to make a panic stop and there is nothing there, you could get in an accident hurting yourself, your loved ones or other people in different car or pedestrians ..
If you plan on doing the job yourself , here is a step by step instruction
this is another good site http://www.tegger.com/hondafaq/maste...djustment.html
http://www.hondaaccordforum.com/HOW_...m_18149/tm.htm
Reply
Thread Thread Starter Forum Replies Last Post
Brake Pedal goes to floor barnfindhonda General Tech Help 10 10-11-2011 01:16 AM
Brake pedal goes to floor CargalX General Tech Help 9 03-13-2010 10:08 PM
Brake pedal goes almost to the floor after engine starts koolaid_kid Tires & Wheels 1 10-12-2009 08:08 AM
Clutch Pedal goes all the way to the floor mingles General Tech Help 4 01-03-2009 03:59 AM
Brake pedal goes to floor after changing master cylinder Hondapt General Tech Help 21 09-19-2007 11:30 AM
Tags
1993, 90, 93, 95, accord, brake, break, cylinder, floor, honda, intermittent, intermittently, master, padal, pedal, soft
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
