Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
How To Dye Seatbelts Properly.
Old 03-16-2010, 11:32 PM
HondaAccordEX94's Avatar
Almost A Senior Member
Default How To Dye Seatbelts Properly.
I did not write this article. I merely found it on a Ford forum by literally Googling "How to dye seat belts". In this article, he shows us how to properly dye a seat belt a new color or re-dye a faded seat belt it's originally color.
Warning: Faded seat belts may have suffered fiber damage and might need to be replaced.
___________________________________
I needed some seat belts for my '74 Bronco and realized that I was missing two of the belts. I had the belts with the latch, but was missing the other two. I have a big box full of seat bets from all kinds of classic Fords that I have collected over the years, and I found the two missing belts that I needed, but they were a tan color and I needed black. I like the look of the original Ford belts and hardware so I decided to dye the tan belts to match, as well as re-dye the black belts so they would look fresh and new.
Here are the belts I was going to dye, the black belt was a little faded, and the tan one was the wrong color:
The belts are cleaned with hot water and soap and left to dry:
You will need some lacquer thinner, and a can of whatever color to want to dye your belts. I used enamel paint, but lacquer also works well:
Some lacquer thinner is poured into a shallow container, an old hubcap works well. You only need enough to fully submerge the belt. Let it soak in for a few seconds:
With the belt soaking wet, remove it and hang it somewhere so it can be painted. You can now completely soak it with the spray paint. You don't want to paint as you normally would with strokes, but you need to depress the nozzle and spray until the belt is completely soaked. The lacquer thinner will let the paint soak in to every nook and cranny. Don't worry about the hardware as it will be cleaned off later:
Once dry, the hardware can be cleaned off with some lacquer thinner on a rag:
The finished belts look new and the dye job will not come off. The tan belt is now completely black, and the original black belt looks new. The lacquer and thinner will not hurt the belts. I have used this method for years with great results every time:
Old 03-17-2010, 01:20 AM
Thumbs up
Very Good DIY Post.
I shall make this a sticky for it's good pictures and for its
great content.
Thank You
jghendrix
11-15-2012 03:24 PM
PinkFloridaFlamingos
08-23-2011 10:17 AM
swegyptian
05-17-2011 12:42 PM
iamgooderer
01-27-2008 05:57 PM
kramrkixass@yahoo.co
11-26-2005 12:42 PM
Quick Reply: How To Dye Seatbelts Properly.
