SURGING IDLE ??
SURGING IDLE ??
http://honda-tech.com/zerothread?id=1003988&page=1
The lower link is from Honda service bulletin, ( 90-93 accords) ,, You need Adobe reader to open the file and read it , if you Do not have Adobe reader, you can download it , it is free, ( download.com )
I want to thank our member RCY for finding and posting the link in our forum
http://www.in.honda.com/Rjanisis/pubs/SN/A990200.PDF
Below is another link .. thanks to our member MALSR
http://www.cb7tuner.com/vbb/showthre...highlight=idle
RE: SURGING IDLE ??
A bit more information; THANKS to mjhenks who posted this in the General Tech section. He read thru these links that Desert posted, & wanted to add his experience...
They suggest checking the water passage on both theIAC Valve and the Fast Idle Thermal Valve. (FITV) Both of mine were "open" but i decided to check inside anyway. Good thing I did. I found that my IAC exit water port was nearly blocked andthe FITV hadcrystallized inside its water passage.(It had a build up of mineral deposits) Once I cleaned all this out my surging idle problem went away. So I would recommend that you take the water passages apart and clean them. Youwill need a tri driver and some silicon to make a new seal for the IAC.
