What are all the different "water-temperature sensors"?
So I have a problem....my 95 4 cyl accord when it gets hot both fans come on for like 7 secs then they turn off then 1 min later they come back on for another 7 secs.....then I turn off the car fan comes on ...and keeps running for a long time....?please help
4th-gen and 5th-gen
1990 to 1997 USA
4-cylinder engine
Beginning in 1993 the Europe/UK Accord 4-door was a different car, built in Swindon UK. Not sure if these sensors & systems are the same.
There's 2 fan switches and 2 coolant-temperature sensors.
Fan switch A is located in the thermostat housing. It switches the fans (both) when the engine is running. Pretty sure that works when the key is turned ON but the engine doesn't actually need to be running.
Fan switch B is located in the nozzle for the upper radiator hose, near the head. This one has authority to switch one of the fans, after the engine has been turned off. There's a timer to prevent the fan from running forever even if the switch-B is stuck.
"ECT sensor" Engine-Coolant-Temperature sensor is located roughly below the distributor. It has a plug with 2 wires. This sensor provides a coolant-temperature measurement for the ECM.
Lastly, there's another temperature sender near the ECT sensor. This one has only one wire and it provides the signal for the dashboard temperature gauge.
1990 to 1997 USA
4-cylinder engine
HondaAficionado
11-30-2010 05:24 PM
Karthigan
11-27-2006 02:55 PM
