Do-It-Yourself Section This section is for requests for DIY help, not for general technical advice.
Windows roll up/down slow? heres your fix!
Old 09-19-2007, 05:26 PM
korrupt1's Avatar
Default Windows roll up/down slow? heres your fix!
Well heres a REAL cheap fix I learned about and figured I would share with you guys
Parts needed:
1 Large box or bag of Q-tips (get good quality, strong type Q-tips)
1 bottle of rubbing alcohol (nothing fancy, just plain old rubbing alcohol)
1 can of Silicone Spray lubricant (I use Pyroil which was availiable at Checker/Shucks/Kragen)
Roll your windows all the way down
Get out your Q-tips and alcohol and wet a Q-tip
Start wiping the window track with the Q-tip (you will do this ALOT and will take several Q-tips!)
After you are 100% sure the track is clean ( I rolled my windows back up and continued every inch of my track) take your silicone spray lubricant and spray the window track (use the little red tube to minimize mess) and allow to sit for a few minutes....repeat with a second spray of lubricant.
Continue on all windows/tracks and then enjoy your windows rolling up and down faster as they used too....I have done this on every car I have ever had power windows on and it really works and has saved me hundreds of $$ instead of buying new window motors and such.
The Q-tips will get incredibly dirty and it will take ALOT of wiping (On my Accord I went through more than 500 Q-tips) but the money saved from not having to buy a new motor was definitely worth the time
(you can removed the door panels and clean also that way if really want to get into but again, the money saved is really worth it)
Enjoy those windows going up and down quickly again!
Old 09-19-2007, 06:18 PM
falkore24's Avatar
Default RE: Windows roll up/down slow? heres your fix!
LOL ..... you got moved to Appearance?!? .... ok?!
Old 09-19-2007, 06:27 PM
HuYnHness's Avatar
this doesnt seem like it fits anywhere and most of us just go to these sections not the general tech section. what exactly are you cleaning? the part around the window that you can see or the actual track thats inside the door? and im guessin this helps from not overworking your motor from a dirty track?
Old 09-19-2007, 08:42 PM
korrupt1's Avatar
yea I am in the appearance section....wanted to be in the DIY section! lol!
and huYnhess, yea, the actual track itself, top to bottom and it will save the window motors from working so hard from the dirty tracks. I did the little trick on my 88 civic after learning about it and saved over $400 since thats what I was quoted for the replacement motors....also did on my 92 Legend and saved those motors as well and did the Accord and was really relieved that my passenger motor wasn't as shot as I thought it was at first.
Old 09-19-2007, 09:15 PM
falkore24's Avatar
Do you also take the door panels off to do the inside? They're likely to be almost as dirty. ..... dangit, there's something that I don't clean on the car?!? Are the tracks felt or rubber (I'm inside now)?
Old 09-19-2007, 09:29 PM
korrupt1's Avatar
Mine were felt all the way through....started at the top and worked my way down following the entire track the window guides through
kicking yourself for finding a new part to clean? [sm=bustedsign.gif]
Old 09-19-2007, 10:17 PM
accords own's Avatar
does this affect tinted windows? it sounds like it might! if it does, make sure to add that to the post.
Old 09-19-2007, 10:23 PM
falkore24's Avatar
true!!! alcohol kills tint adhesive. I found out the hard way that alcohol is the ONLY hosehold item that will remove the glue!!! I couldn't believe it when lighter fluid didn't work!!!
Old 09-19-2007, 10:42 PM
korrupt1's Avatar
but your wiping all the alcohol away with continued Q-tip treatment and then the silicone spray removes any excess alcohol.....have never had any window tint troubles.......acetone removes window tint glue really well too....rip off old tint, spray some acetone, scrape with a flat razor....clean window ready for new tints......and I use a hair dryer to remove the rear tint....slow process but it works! [&:]
Old 09-19-2007, 11:16 PM
falkore24's Avatar
I tried acetone ..... it might not have been the 100% approved as a gas addative kind, but tried and failed. As for the Q-Tipping the alcohol, I see your point, but I think I'll try it with something that I know won't take off the tint ..... hehe, maybe lighter fluid! Are you sure that what came out was just crap and not the dye from the felt? I'm also concerned with degrading the felt, so maybe I'll try with water and dilute cleaner. I'll have to look into what cleaners are good for felt .... I'm a building engneer and felt is a waterproofing membrane. I'm sure that at least one of the architects in my office has the answer! .... and I love to email the entire office with non-work stuff, LOL (about 50 people ... not a huge outfit).
Quick Reply: Windows roll up/down slow? heres your fix!
