1988 governor?
RE: 1988 governor?
if its fuel injected then it has to have a computer that controls the engine. You are correct, the LXi versions have 120hp(i assume the i stands for injected).
I would figure out the general idea that the shape of your intake tube goes, then find another car like civic or newer accord that has a similar shape, and buy a cheap one on ebay and make it fit.
RE: 1988 governor?
alright well problem is I only have $40, and im debating on getting a cold air intake or doing the $50 paint job with tremclad and mineral spirits and foam rollers.
could I make an air intake out of
[ol][*]Cone filter[*](1) 90-degree bend 3.5in to 4in (or whatever size you chose) PVC pipe[*]One foot or so straight PVC pipe of the size you chose[*](1) 90-degree bend PVC pipe[*]Assorted PVC fittings, a closet fitting, depending on your filter[*]Screws, small nuts and bolts for the closet fitting[*]PVC cement [/ol]
RE: 1988 governor?
could, would be almost as expensive, if not the same as just buying a cheap one on ebay, which the ebay one would look far better. also using rollers to paint a car................not going to end up looking good, could do a far better job with just spray paint.
RE: 1988 governor?
spray paint really? and thanks a lot your really helpful (serious). I was banned from ebay some time ago though, I cant even register an account to buy now a days. I thought it would be cool to make money online selling **** when I was 15 and messed up somethings and got kicked off.
RE: 1988 governor?
All paint jobs are spray on, it simply just can not be done well with a roller or brush. The intake looks somewhat similar to a 5th gen accord, juts looks to have maybe a little bit more of a bend in it. I would take some measurements as to how long your stock intake is, then compare it to some other cars, as you wont be able to find one for your car.
raydavid93
03-16-2013 09:23 AM
