1996 accord ex 2.2 vtec distributer
Old 06-20-2016, 01:51 PM
Chobely's Avatar
Default 1996 accord ex 2.2 vtec distributer
The F23A1 is the only direct interchangeable engine for the 96-97 accord which comes from a 1999 accord my question is will the distributer from the 1999 work in a 1996 ???? As the distributer from 96-97 is a highly sought after part and hard to come by used can anyone help me with this????????
Old 06-20-2016, 04:07 PM
30100-P0H-A01 is the distributor from 1996 EX
30100-PAA-A02 is the distributor from 1999 LX or EX
Not sure, but I think they revised the timing sensors inside the distributor. It's almost like you have to grab the PCM & wiring along with the engine.
Old 06-20-2016, 04:17 PM
Chobely's Avatar
Default 96 accord distrbuter
thank you and this is what I had thought because there are shelves loaded with that paticular distributer but you cant find the one I need so rather then spending all that time and money I'll wait out a parts car ! Unless someone has any ideas but once again thank you for your input JIM!!
Old 06-20-2016, 07:56 PM
Do you have the donor car or just the engine?
Grab the PCM and the engine wiring harness, and I bet there's somewhere you can get an adapter harness. I've heard of people putting an F23 into their 5th-gen so it isn't impossible.
Old 06-23-2016, 12:18 AM
Chobely's Avatar
sorry for delay jim no I got just an believe it or not engine with only 80.000 on it so I had to jump but no wiring and as of today still no distributer so I'll wait it out but once again thanks for your input I'm just learning hondas
Old 06-26-2016, 08:56 PM
Chobely's Avatar
Default 1996 accord ex 2.2 vtec distributer UPDATE!! New problem
Ok I have 1996 accord ex 2.2 vtec I have since swapped engines from the f22n to the f23a the only direct interchange which is a 2.3 everything went smooth until I finally aquired the very hard to get distributer two year ex only now the new problem is when I try to install it does not seem to reach the camshaft almost like it's to short now I'm at a total loss please can anyone help I've been waiting weeks for the distributer only to still be stuck?????????
I moved this post into your earlier thread so it's all together.
Jim Blake
live2rice
08-01-2008 02:55 PM
cordo88
04-16-2008 09:48 PM
live2rice
03-08-2008 06:19 PM
cbinva
02-10-2008 10:36 AM
g1teg
10-03-2006 05:01 AM
Quick Reply: 1996 accord ex 2.2 vtec distributer
