This may the end of my car....?
Old 03-23-2011, 08:27 AM
mockingbird89's Avatar
Unhappy This may the end of my car....?
Well...finally got my power restored and my gas mileage back to normal on my 93 accord after cleaning out the EGR ports. I was heading to work this morning on the highway and my car shuts off going about 60. I was dreading the thought but the only thing I can come up with is my timing belt. Any thoughts on this one cause I really would hate to scrap my baby but I don't think putting in a used engine would be very practical when the car has over 307,000.
Any thoughts or suggestions :")?
Jonathan
Old 03-23-2011, 11:20 AM
If the timing belt broke, it would sound very different when cranking the starter.
Measure your compression - if the timing belt broke, your compression wouldn't be very good.
Old 03-23-2011, 12:00 PM
I don't know if this makes a difference or not..but my power steering shut off as well. I mean unlikely but alternator or fuel pump could be culprit?
Old 03-23-2011, 04:41 PM
There's no carburators in 1993, correct???
Power steering is on its own belt. Alternator & AC compressor share the other belt. Fuel pump isn't on any belt; it's electric inside the fuel tank.
Losing the alternator belt shouldn't stall the engine.
Old 03-24-2011, 10:40 AM
well...it started right back up after I was about to go have it towed last night. Drove it about 50 miles around doing errands and still no signs of anything. What would cause that?
Old 03-24-2011, 11:34 AM
Flaky ignition switch? Can you get it to stall by wiggling the key?
You could check whether the distributor has power during one of it's no-start episodes.
SykVSyx
North East
05-01-2009 05:35 PM
Goldnknight22
04-13-2009 11:24 AM
Zer0Vtak
02-21-2008 12:07 AM
thunder_x
05-15-2007 10:51 PM
Quick Reply: This may the end of my car....?
