Accoed 2013 Oil Issue
Hello All,
I have 2013 Accord Lx , bought used at 40K miles, I got oil changed at 41K miles (Full synthetic 0w-20)
Now i am at 47K and noticed from last few weeks that the oil pressure light in dash flashes once in a while (Mostly when i apply break on highways) and goes off quickly.
So i did some research and checked the oil level -
-in dash it says 20% Oil life remaining
-under the hood i found the dip stick was totally dry (cold check) , i didnt even start the car after i saw this.
I added almost 3.5-4 quarts of new oil and then checked the oil level in dipstick, looked ok.
then i started the car , it was more noisy initially and then settled down to normal noise.
also saw diesel like smoke coming out of the exhaust.
Turned off off the engine about 3-4 minutes after letting it run
now oil level looks perfect, but obviously color changed to dark brown versus the color of new oil which i just poured.
So now i plan to go for oil change in couple days, and not gonna drive until then.
Please let me know if this situation is normal (oil getting vanished /burned or leaked )?
i dont think it leaked, also i never faced these issues with my 99 accord.
Also, i found alot of other folks complaining about it here - 2013 Honda Accord Excessive Oil Consumption: 19 Complaints
Please suggest what should i do in this situation(Complaint Honda/should there be a recall ) and how to prevent any engine damage due to this.
