At 70mph I hear the engine make noise
When I get to about 70mph I hear the negine make like a revving noise(if that makes sense) and I could swear the gas pedal gets a little harder to push. Is it me? or is this something?
RE: At 70mph I hear the engine make noise
there are lots of possible causes why engine makes a noise. it would be best to check all the honda engine parts such as the check timing; valve timing; check if the engine overheats; check the bearing, wristpin slap or failing knock sensor. keep us posted of what other things did you found out.. good luck
JustinFanatic
09-02-2006 07:36 PM
