carb/efi
True, maybe easier to swap to the motor with one already set up, of course there are the "other" things needed after doing this (wires harness, ECU, EGR stuff, ect). But to answer the question, Yes it can be done. A webber conversion might be another option....what are you trying to get/solve by this?
ESP makes mount kits for D series B series engines that can be swapped in your gen accord.
If you want power your better off doing a swap. The cash to power ratio will suck if you try and build your stock engine.
