Cruise Control Not Working.
I have no idea what to do or what to check in order to find out why my cruise control isn't working. I'll be checking the fuse in a few minutes. Any other suggestiond if the fuse is ok?
There are several things it could be.
Did it ever work since you had the car?
Can we assume the main switch lights up but when you go to set it NOTHING happens.
Simple visual checks, is the cruise cable connected to the throttle body. Is the switch on the clutch pedal properly seated (closed) when the clutch is not pressed.
aatc20
09-25-2006 04:28 PM
