D4 Light Won't Stop Blinking
Old 10-13-2007, 03:30 AM
PhilipK's Avatar
Default D4 Light Won't Stop Blinking
I have a 1993 Honda Accord SE and I just put a low milage JDM transmission in it. I did the swap perfect, nothing left over everything plugged in. I connected the service plug together with a wire and the D4 light still just blinks. The transmission level is perfect. I hear a slight high pitched sound coming from the engine bay, but not loud enough to hear inside the car. When I took it for a drive is is very sluggish through the gears. Do you guys think that may have to do with the speed sensor? I did not un-plug the fluid from it, just pulled it out and stuck it back in. Let me know what you guys think. Thank you, Philip.
Old 10-14-2007, 09:39 PM
Hotgirl1
Default RE: D4 Light Won't Stop Blinking
Hey i have the same problem..I thought it was soppose to do that.... except i have an automatic
Old 10-14-2007, 10:39 PM
deserthonda's Avatar
you need to jump the SC connector ,chk the codes and input them here
Hot girl ,you need to do the same thing
Old 10-15-2007, 01:38 AM
PhilipK's Avatar
I jumped the blue 2-pin connector on the pass side. The D4 light just keeps on blinking, is there a certain way to do it?
Old 10-15-2007, 06:31 PM
PhilipK's Avatar
Anyone know what it means when it just keeps on blinking with the pin in? Or is there a special way to do it?
Old 10-15-2007, 10:53 PM
you need to read the # of flashes on the dash board
Long flash = 10
short flash = 1
so if you get a long flasf, a slight pause and 4 shorter flashes, it is code 14 ... count the flashes more than onces to be sure you get the correct code and also in case there is more than 1 code stored ..
So ,jump the connector, put key on and start counting .
Old 10-15-2007, 11:35 PM
Hotgirl1
so can i get a step by step manual to this...for the slow folk out there( a couple of pictures,exactly where is it for this model)...lol
Old 10-16-2007, 12:13 AM
PhilipK's Avatar
7 short blinks, let me know guys.
Old 10-17-2007, 04:57 PM
PhilipK's Avatar
Got it fixed, shift silonoid.
Old 10-19-2007, 01:14 PM
Prizma's Avatar
What did they do to fix it?
My D4 light is just completely off. Doesn't blink, nada.
Quick Reply: D4 Light Won't Stop Blinking
