engine shuts off while driving.... help??
Old 07-21-2014, 08:09 AM
Butterd97's Avatar
Default engine shuts off while driving.... help??
Doesn't happen often, but from time to time while driving down the road you will notice almost a power surge and everything turns off. lights radio engine....everything. after literally a second , you can restart the car and it keeps on going. Some one mentioned a sensor that could be causing it but didnt know the name of it. Any thoughts on this or advice on how to fix.
Thank you all
Old 07-21-2014, 05:40 PM
There are a few things that come to mind. If you could let us know the year and engine it would help as well.
1. Check all battery connections to be sure they are clean and tight - not just at the battery but the "other ends" as well.
2. The electrical part of the ign switch can and does fail.
Again if you could narrow down the year/engine and that it might help for more ideas.....or even throw out the ones I posted
Old 07-24-2014, 07:31 AM
Butterd97's Avatar
its a 97 2.2 . I've had a few people mention the IGN switch failing in their car and it doing the same thing.
Old 08-20-2014, 08:11 AM
Butterd97's Avatar
Really still wanting to hear some opinions on this since i posted the the year/engine. It did it again yesterday and took a few minutes to actually start back this time. Also why would the fans only kick on when the car is off and will not kick on while the car is running and starting to overheat?
Old 08-22-2014, 06:51 AM
Butterd97's Avatar
anybody??? really looking for some help here
Old 08-22-2014, 07:47 AM
You've received good advice.
Time to act on it and find out whether battery cables are in good condition and securely connected.
Then if problem repeats, you need to check for missing battery voltage at the blk/yel wire of the distributor connector. It should have 12V w/ the ignition switch On. If not, ignition switch should be replaced.
Due to the nature of an intermittent problem, you must wait until no-start condition is present to perform the voltgage check.
Mabworks
05-16-2019 11:57 PM
matthewwalk
04-27-2012 02:50 PM
vprevot1
02-21-2010 07:14 PM
gcfishguy
04-19-2009 08:10 PM
mike_tran
08-22-2007 05:17 PM
Quick Reply: engine shuts off while driving.... help??
