H22 swap trying to get inspected
Old 04-15-2015, 11:08 AM
Dpk33's Avatar
Default H22 swap trying to get inspected
I bought a 2000 accord not knowing that the guy did a motor swap.. It had a check engine light on and when I went to get it scanned for codes it said it was unreadable and the tech said it couldn't be inspected, is there any way I could get this car inspected?
Old 04-15-2015, 12:42 PM
Depends on where you are. Different states have different rules for how that works.
Old 04-15-2015, 03:53 PM
Dpk33's Avatar
I'm from New York, it was originally from Florida
Old 04-15-2015, 05:29 PM
Back tracking some elses "work" can be fun. First are you sure it is a H22 motor, if so do you have any idea of what year the engine it out of.
Did they give you anything to get started on or just the fact that through the DLC there was no connection?
I hope you like electrical/wiring
Old 04-15-2015, 06:57 PM
Dpk33's Avatar
From a '95 prelude
Old 04-16-2015, 08:22 AM
The 1995 Prelude is OBD-1 so it won't have the same OBD-2 DLC.
"Generally"
For an OBD-2 car (yours is OBD-2 because it's newer than 1996) you are normally not allowed to go backwards in year. Exhaust emissions for 2000 are much tighter than they were for 1995, so the 1995 Prelude engine is a step back to a higher-polluting engine.
Old 04-17-2015, 05:25 PM
What ECU/PCM is in the car?
Old 04-20-2015, 01:35 PM
Dpk33's Avatar
Default H22 engine
How much is my 2000 h22 swap with bad electrical worth?
Old 04-26-2015, 04:46 AM
Hard to call.....what is wrong with the electrical?
Old 04-26-2015, 04:53 AM
Merged your posts.......I didn't realize you had two.
I'd start by looking at the PCM/ECU that is in the car and get the numbers off of it.....we can then see if the ECU is OBD-I or ODB-II.
live2rice
06-17-2011 03:04 PM
aidenshinoda
03-24-2008 02:06 PM
blahhh3
01-31-2008 03:45 PM
blodisnut
12-14-2007 03:52 PM
YeuEmMaiMai
11-06-2006 10:02 AM
Quick Reply: H22 swap trying to get inspected
