Man bro i need help. is anyone gonna help me on here!!!!! ENGINE SWAP HELP!!
What is the best engine swap for a 93 accord! has a f22a6! want better engine that can handle turbo! found turbo on ebay ! supposedly adds 640 hp!? but if its a lie i could careless. ill replace the engine in the next couple of years anyways! help plz. thinking about h22a! right now the accord is fully stock. want to do some head work but dont kno which engine to buy!
the f22 is actually the best engine for boost, because it has steel cylinder walls and a low compression ratio.
The h22 is not good for turbos because it has frm cylinder walls and a high compression ratio.
boost your stock engine and you will see 300hp on about 2k worth of parts.
If your a auto trans for getabout it and spend your money on a 5speed swap be4 you even think of adding anymore power to your car.
the h22 sleeves are really good sleeves and very strong they just don't like aftermarket pistons. So it's really the compression ratio that holds the h22 back from boosting allot.
Zai80
10-05-2010 04:18 PM
Zai80
10-03-2010 09:32 AM
HondaAficionado
04-06-2009 01:00 AM
