Ignition coil
Old 07-14-2008, 06:40 PM
FlyLow's Avatar
Default Ignition coil
Is it necessary to replace the ignition coil (the one under distributor cap) after a certain time? Does the tip wear out? Or is there a way toclean the tip with something?
2dr 1999 Accord LX 2.3L 5-spd
Old 07-15-2008, 08:13 AM
Default RE: Ignition coil
No schedule for replacement. Wait till it breaks.
I usually scrape the crud out with a knife. Theres no motion against that, so it usually doesn't get bad. Is it missing the little spring so the spark has to jump a gap??
Old 07-15-2008, 08:07 PM
FlyLow's Avatar
If you mean the spring on the distributor cap that is supposed to touch the coil tip, then yes it is there. The tip looks delicate i was affraid to scrape it off. What does it look like when new? Any one have a picture?
Old 07-16-2008, 08:33 AM
Coil #11 isnt shown in much detail.
Old 07-20-2008, 06:36 PM
FlyLow's Avatar
so I just changed the distributor cap and the rotor. I put a bunch of dielectric grease on wires and caps connectors. The car started for a few seconds just fine, and then died, and now it wont start. What the happened? (same car as above)
Old 07-20-2008, 07:49 PM
FlyLow's Avatar
Turns out the fuel pump isnt working, cause i cant hear it when ignition is turned on, the fuse looks fine. How does the pump go out from changing distributor cap and rotor?
Old 07-20-2008, 08:42 PM
FlyLow's Avatar
The manual says to test the lead #5 on connector that is on the fuel pump for voltage. Is that with ingnition on or off? I didn't get voltage from there. Has anyone had this problem?
Old 07-20-2008, 09:29 PM
FlyLow's Avatar
Car has 110K miles, how long do fuel pumps last?
Old 07-21-2008, 09:34 AM
Turn key to ON but not immediately to START.
Main relay gives power to fuelpump for about 2 seconds. Test that wire during that time.
Old 07-21-2008, 04:35 PM
FlyLow's Avatar
Ok I got roughly 12V on one of the leads for about 2 seconds, on the fuel pump connector, after turning the ignition to ON, just before start. So it has to be the fuel pump. Is there a way to test the pump without taking it out?
Quick Reply: Ignition coil
