Putting a vtec in my accord, it has 2.3 non vtec now
i have a 1998 accord with a 2.3 non vtec with a 5 speed, while i'm driving at 3k rpm i can hear a knocking noise but if i give just a small amount of gas it gose away or if i eazy off the gas it will also go away, however it sounds like it coming from the right side of the car, i thought maybe a rod or main bearing, but someone said it could be a wirst pin....who knows??? anyway i found a wreck 1998 accord with a SOHC vtec and i want to put it in my car, my problem is i have a 5 speed and it has a auto trans.....if i use the vtec motor what wiring and ecm do i use ? mine or the one from the wrecked accord being it's a auto and i want to keep my 5 speed, thanks you guys
the engine is the same you can bolt your current 5speed f series trans to your new engine. Bolt patterns are the same. You don't need a cputer for a 5speed trans.YOU ARE THE COMPUTER
You will need to wire up vtec and vtec pressure switch here is a ling for ya...read bth links
http://hondaswap.com/general-tech-ar...re-vtec-40811/
http://www.hondacivicforum.com/forum...ad.php?t=73241
cd51994accord
01-30-2014 12:56 PM
TJH
11-21-2013 04:56 PM
stresser
08-17-2010 08:04 AM
