govenor
Old Dec 13, 2007 | 01:07 PM
02BlueAccord's Avatar
Default govenor
im know this subject has been talked about before. i was just wondering if there is one on the 02 accords and how to take it off
Old Dec 13, 2007 | 01:09 PM
sir_nasty's Avatar
Default RE: govenor
as far as I know almost every accord from 96 or 97 on has a governor at about 110-120. If you have one you should be able to buy a chip realatively cheap that will remove it.
Old Dec 13, 2007 | 01:22 PM
klrspz's Avatar
Default RE: govenor
eh, i've gone 130 on level ground recently... so i dunno.. and the spedo reads up to 160
Old Dec 13, 2007 | 01:34 PM
falkore24's Avatar
Default RE: govenor
mine had a 111 mph limit. I installed the V-AFC and it was still there. Before I had it tuned, I found a setup on the internet, plugged it in and the limit disappeared. The fastest I've gon is 137. I think is's safe to say that there is no longer a speed governer
Old Dec 13, 2007 | 01:39 PM
Default RE: govenor
ok. so what chip or what not do u recomend to get rid of the govenor?
Old Dec 13, 2007 | 01:44 PM
falkore24's Avatar
Default RE: govenor
E-Manage FTW!!!!
I have the Apexi V-AFC, but I'm not sure that it was supposed to eliminate the top speed.
Old Dec 13, 2007 | 01:48 PM
finch13's Avatar
Default RE: govenor
I was going to say chip a P28 or P72/75 ECU, but then I read that it's an '02 with OBDII so that's out of the question. I don't believe any OBDII Hondas that new have been sucessfully chipped so an APEXi or GReddy piggyback unit will be need or Hondata K-Pro.
Old Dec 13, 2007 | 01:53 PM
Default RE: govenor
ok thanks. any site recommended for this kind of stuff?
Old Dec 13, 2007 | 02:05 PM
finch13's Avatar
Default RE: govenor
Just checked. K-Pro is only for RSX/TSX and a few other cars... lame. I would not buy any sort of chip out there... they are usually just stock spark tables with longer injector pulses for "more" power a.k.a burning tons of gas at no real benefit. I'd just ask falkore about the V-AFC and exactly what he did to get rid of the governor.
Old Dec 13, 2007 | 03:14 PM
Default RE: govenor
k cool thanks.
