Starting issue 97 accord ex
Old 09-22-2016, 11:40 PM
byronb860's Avatar
Default Starting issue 97 accord ex
Hello guys, new here, I have a 97 accord that clicks when I try to start it. I've replaced the battery and starter on it and still has the issue at times. Any idea of what it could be? Thanks
Old 09-28-2016, 12:43 PM
bicklebok's Avatar
More than likely its your starter. It could also be a bad connection, etc.
In my case, my 97 started doing the same thing. I checked the battery and it was good. I didnt even troubleshoot anymore. With 205,000 I just went ahead and replaced the starter, which was the problem.
Old 09-28-2016, 07:30 PM
byronb860's Avatar
Thanks bicklebok, could it be that the new starter is bad already you think? I'm going to clean all connections hopefully tomorrow
Old 09-29-2016, 07:19 AM
bicklebok's Avatar
Try tapping on it and see if that makes a difference. Also, checking the contacts like you said is a good idea. You can also take the starter to Auto Zone and have it tested.
If you replaced the old starter with an inexpensive rebuilt one, I wouldnt be surprised if it's bad already. I just bought a high quality rebuilt starter for mine($160) and it was bad. Had to pull it right back off. So I bought another high quality rebuilt starter and although it works, it is giving problems too. Pretty sad that its hard to get good rebuilt parts these days.
Old 09-29-2016, 08:26 AM
Suggest cleaning and tightening both battery connections. Symptoms can be caused by weak connection or bad battery cable (check for voltage drop).
Old 10-02-2016, 01:35 PM
byronb860's Avatar
I've cleaned and tightened down all ground connections. I also cleaned the positive cable on the battery and starter and I'm still getting the same issues. Once the CEO light came on after a while, git it scanned and was told it's the crankshaft position sensor. Would that be it?
Old 10-02-2016, 06:58 PM
CPS will prevent engine from starting, but not cause a no-turnover or clicking from solenoid. Possibilities are bad battery, connections, bad battery wire/s, or faulty starter. You have replaced battery and starter, and cleaned connections. That leaves faulty battery wire/s as remaining possibility, if all work is good.
Dts91
09-01-2010 03:15 PM
stubs
08-06-2010 10:29 AM
leg_of_tape
07-16-2010 06:19 PM
jacks132
09-02-2009 10:28 AM
RDX
02-01-2008 05:15 PM
Quick Reply: Starting issue 97 accord ex
