What engine should I swap on my '92 accord? - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
LinkBack Thread Tools Search this Thread
Old 11-11-2011, 12:40 PM
Default What engine should I swap on my '92 accord?
Hey everyone I'm new to this forum. Figured I would start doing some learning and little research online for my new car fairly new at modding and boosting. A friend of mines just gave me a '92 honda accord automatic for free because he did not want to fix it. (relay transmission computer) he did not have the time. I just want to use it for everyday driving, but want it to have some BASEBALLS to it. So here I have it, and I'm thinking of getting the engine swapped. I had an H22 in mind. Does anyone have an opinion on what should I do or how can I do this?
Old 11-11-2011, 01:23 PM
Thumbs up Hello Member... :)
Hi and Welcome to the Forum...
The 1990 thru 1997 Accords and Preludes and Acura CL's can be your engines to look at while thinking about swaps.
Thanks to the Honda engineers and designeers between these cars make the swapping of engines between these cars easier because of the similar chassis and body sizes and styles.
Both the Accord and the CL's which really are one and the same do share a relationship with the Preludes.
This helps make it fairly simple for you and your crew to bolt in a bigger and a more powerful engine .
My personal choice of a swap would be the 220 HP JDM H22A from the
1997 thru 2001 Prelude S , This engine was even offered in the Accords
back then..this should show you that this would be a compatible donor swap..
I hope this will get you on the road to success..if you decide to pursue your issue..
Old 11-17-2011, 03:54 PM
the h22a is a great fit for your car i have a 93 accord and it fits right in. heres a guide Accord Chassis with H22 Engine - Tech - Sport
and a good place to find the engine for cheap is
jdmtigerjapanese.com/
good luck im doing the same thing.
Old 11-17-2011, 04:54 PM
g22cd5's Avatar
Supper Moderator
I would STRONGLY recommend staying away from that import site "jdmtigerjapanese.com/" I have heard and read ALOT of horror stories about the engines they sell.
hmotorsonline.com has a very good rep. and good prices too
If you have a issue with engine hmotors sells you they will make it right. This other place you MIGHT be lucky to get a phone call back. Also that company is overseas unlike hmotors in here is the states (California)
Old 11-18-2011, 03:10 PM
Thanks alot you guys, those were some helpful tips. I'm definately going to be checking the site and keep doing some more research.
Reply
Thread Thread Starter Forum Replies Last Post
96 accord engine swap with a 94 engine D-Rod33 General Tech Help 9 11-02-2011 08:38 AM
Im going to buy a 93 accord. and do a cylinder swap or full engine swap. HELP Levibyz Engine & Internal 1 06-01-2011 02:10 PM
Girlfriend wants an Accord...what engine should I hunt for? donniejr81 Engine & Internal 11 12-31-2010 03:05 AM
1991 - More of a body swap than an engine swap mfskarphedin General Tech Help 5 06-06-2010 10:33 PM
***Engine Swap***** 2000 Accord v6 3.0 engine put into 2002 accord Ex v6 3.0 2dr StatzFinest Engine & Internal 3 02-10-2008 12:32 PM
Tags
92, accord, car, codes, compatibilitty, engine, engines, fit, guide, honda, long, mods, motor, put, swap, swapped
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
