whats the difference? Whats better?
F22b1:
Bore × Stroke: 85.0 × 95.0 mm
Displacement: 2156 cc
Compression ratio: 8.8:1
Valve Configuration: SOHC, 16 valves (4 valves per cylinder), VTEC
Max power: 145 hp (108 kW) @ 5500 rpm
Max torque: 147 lb·ft (199 N m) @ 4500 rpm
F23a1:
Bore × Stroke: 86.0 × 97.0 mm
Displacement: 2254 cc
Valve Configuration: SOHC, 16 valves, VTEC
Compression ratio: 9.3:1
Max power: 150 hp (112 kW) @ 5700 rpm
Max torque: 152 lb·ft (205 N m) @ 4900 rpm
Pretty much just .1L and a little bit of power.
F23a1:
CP1
11-30-2012 10:21 AM
liam71234
11-01-2007 07:45 PM
