02 EX V6 TCS / Check Engine light on - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 10-09-2010, 08:15 AM
Default 02 EX V6 TCS / Check Engine light on
2002 Accord EX V6 - We were just driving down the road last night and the TCS and check engine light came on. Car is running fine other than that. It has 93K miles on it.
Old 10-09-2010, 12:11 PM
hondadude's Avatar
There are a million things in the car that can trip codes
It would be a great idea to have the codes scanned and then repost back what the actual codes are.
Old 10-09-2010, 03:27 PM
Default ran a scan
Ok - I took it to Autozone and they ran a scan that came up P401 EGR flow insufficient. They didn't have the valve in stock so I'm looking for it. Why would that also make the TCS light come on?
Old 10-09-2010, 03:40 PM
Its not the valve. It is going to be a plugged up port. Common problem on the 98-02 V6. There is a TSB with the procedure. Just google 99-085 TSB. The first hit shows the procedure.
I recently helped my friend with this. It really isn't too bad to do. The throttle body gasket stuck to the intake, so we had to scrape that off. We replaced that gasket. I skipped steps 8-13. Just used the drill bit by hand to clean out the passage, then a test tube cleaner + throttle body cleaner to remove the rest of the buildup stuck on there. We also replaced the gasket between the cylinder head and the intake manifold just to be safe.
Old 10-09-2010, 04:09 PM
Default thanks for the tip
I'll look into it.
Reply
Thread Thread Starter Forum Replies Last Post
TCS/Check Engine light TeamSumner General Tech Help 3 06-04-2012 11:34 AM
TCS and Check Engine P7040 and P1676 codes rahulmunjal General Tech Help 5 02-27-2012 12:10 PM
02 accord check engine and tcs light on aspringer210 General Tech Help 1 02-26-2012 07:35 PM
2002 Honda V6 Check Engine and TCS Lights calspud General Tech Help 4 10-28-2007 12:59 PM
Check Engine and TCS Alert on 03 Dj Insanity General Tech Help 2 05-21-2007 10:05 PM
Tags
02, 085, 2002, 99, accord, belt, check, egr, engine, fix, honda, light, safe, seat, stuck, tcs, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
