Sponsored by:
Sponsored by:
Fuel Pump
Old 08-14-2009, 10:48 AM
Fixeruper's Avatar
Default Fuel Pump
My 89 Accord LXi Sedan 2.0 has a Carter fuel pump in the tank.
Anyone got an idea on how to see if the pump is working up to it's potential and if I need to replace it which name brand should I use.
Thanks
Old 08-14-2009, 06:39 PM
You can install a fuel pressure gauge and run it out from under the hood to the windshield. Tape securely to windshield where you can see while driving.
Drive and check that fuel pressure is maintained w/i spec under normal and hard acceleration driving. If yes, the pump is doing fine.
If not, it's either the pump or the fuel pressure regulator. If fuel flow is inadequate or regulator is allowing too much bypass, fuel pressure will decline. If fuel pressure is good except under heavy acceleration, suspect the fuel pump. If pressure is too high, bouncing around or marginal all the time, suspect fuel pressure regulator.
Old 01-09-2010, 10:10 AM
Fixeruper's Avatar
Question
Thanks for your help TexasHonda.
I pulled the gas tank and it looks like Georgia red clay inside. Rust everywhere. All the internal parts have been turned orange. The fuel pump looks to be a Spectra and it may not be all that old. I ran some water through the pump to test it. Do you think I damaged it?
rockhoundrob
04-11-2014 11:41 AM
Westjoe64
10-15-2012 12:11 PM
kissbally78
01-18-2009 07:14 PM
boots
03-17-2006 06:01 PM
driver93
12-19-2005 05:22 PM
Quick Reply: Fuel Pump
