2003 Honda Accord ex
Old 03-02-2021, 11:27 AM
Kyrel Harewood's Avatar
Default 2003 Honda Accord ex
Hey i have a electrical problem with my 03 accord for some reason when I’m using my left turn signal it will flash the low and high beam and when i turn on the low or high the left signal will stay on solid i try checking the wires etc also my sunroof not getting power either from the connectors anything i can check before taking it to a shop I’m mechanical incline but the electrical something that been kicking my butt
Old 03-02-2021, 01:21 PM
When unrelated things start acting flaky like that, the first thing I suspect is a bad ground somewhere.
Old 03-02-2021, 05:54 PM
Locate the grounds for the headlights. Each headlight has a ground below the light and are bolted to the radiator support or the bumper bracket. You may be able to locate them without removing the bumper. Once located, remove the bolt and clean the bolt and eyelet with a wire brush or sandpaper to ensure a good connection.
JulieG73
06-24-2020 05:25 PM
skyfire322
08-29-2019 04:19 PM
rslayback
02-25-2010 07:08 AM
rtsulliv4801
02-04-2009 05:33 PM
Quick Reply: 2003 Honda Accord ex
