0W20 Engine Oil? - Honda Accord Forum - Honda Accord Enthusiast Forums
Reply
Thread Tools Search this Thread
Old 02-19-2012, 01:06 PM
Default 0W20 Engine Oil?
The Honda owner manual recommends using 0W20 synthetic engine oil in their new Accord. I believe Toyota is doing the same. From what I've read, this oil was developed to help the manufacturers meet fuel economy federal guideline requirements for certain type cars by helping the overall average MPG across the board.
My question is, "Is 0W20 the best oil to use for protecting the life of the engine, or, is the best oil to use to help Honda meet fuel mileage guidelines?" Honda states that 5W20 is acceptable in lieu of 0W20.
I want to use the best oil for the life and lubrication needs of the engine. I don't really care about helping Honda meet fuel economy standards if it means using a thinner less lubricating oil.
So, what weight of synthetic oil do you recommend? FYI, I live in the Houston, TX area so cold temperature is not a concern.
thanks...............
Old 02-19-2012, 01:16 PM
I would follow Honda's recommendation. They should know best. Besides, I would think that anything that increases fuel economy should also be good for the car.
Old 02-19-2012, 02:36 PM
0 weight has the consistency of water.
I couldn't imagine that it give much long term protection against wear on the metal parts of the engine. I would not run it my car that I was going to keep for a while even if it was recommended my Honda. IMO
Old 02-19-2012, 03:06 PM
But the fact that this 0W20 is synthetic might help?
Old 02-19-2012, 05:51 PM
Quote:
well yes I would guess so but I think they (Honda) might be sacrificing longevity (cuase there is not much money in it for them for us to drive these cars 20+ years) for MPG which does sell cars.
I run 5 weight in my sportbikes but I def do not expect them to last much more than 30-50k miles. However I want want my Honda (car) to last 300K miles.
Old 02-19-2012, 06:35 PM
For the newer cars that recommend 0W-20 or 5W-20, these oil viscosity are used for fuel economy; but, at the same time provide protection for the engine. Many of the oils sold under these viscosity meet GF-4 standards. Generally, the motor should out-last many other parts of the car if you do regular recommended maintenance, check fluid levels, etc. Mobil 1 0W-20 and 5W-20 meet GF-4 standards, as well as many other quality synthetics out there.
I have close to 90K on my 2009 already.
Old 02-19-2012, 07:11 PM
EXV6NIGHTHAWK's Avatar
Living in Texas, I would consider using 5w-20 in the summer.
Old 02-19-2012, 07:52 PM
OP is talking about a new Accord, right? Designed with the bearing clearances appropriate for a 20 weight oil.
Oil "weight" numbers are an archaic system that relates to viscosity in a very obscure way.
The number without the "W" is the weight of the oil, so 20-weight is what your engine calls for. There is no lubricating oil having a viscosity that's constant over the range of temperatures from 32F to 220F.
0W means "winter" and so when the oil is at a temperature of 32.F it has the viscosity of a "0-weight" oil. That's still A LOT thicker than a 20-weight oil at operating temperature. So even though it says 0w, it's not really a 0-weight oil. Confused yet?
Zero-weight having the consistency of water? I gotta do some homework with actual viscosity numbers, but I don't think that's true.
Old 02-20-2012, 01:18 AM
Tenbrooks, you think like I do, so we're both right!
Like you, my concern is engine longevity w/ minimum problems, not 0.13% better fuel economy.
I've always used the thicker oil option, 5W-20 in your case, as long as the temp ranges
match up to the owners manual. Houston is - duh - hot, too.
Old 02-20-2012, 08:08 AM
0W means "winter" and so when the oil is at a temperature of 32.F it has the viscosity of a "0-weight" oil. That's still A LOT thicker than a 20-weight oil at operating temperature. So even though it says 0w, it's not really a 0-weight oil. Confused yet? --YES
--that was based on the little bit of oil knowledge I have. It was def an opinion not a fact I am I vary open to being corrected
Reply
Thread Thread Starter Forum Replies Last Post
What the deal with 0w20 oil?? zena_fan2000 General Tech Help 13 03-01-2012 05:49 AM
Should I prime the engine with oil??? how to do safely do so after oil change PinkFloridaFlamingos General Tech Help 3 08-24-2011 12:35 AM
oil, Oil, OIL! 91 Accord MiyashiMeism General Tech Help 4 09-05-2010 02:12 PM
Help, regular oil or synthetic oil? Many Many Thanks jasonan Engine & Internal 5 08-28-2009 11:26 PM
BEST OIL AND OIL FILTER FOR OUR ACCORDS NOW nygamble General Tech Help 11 06-11-2006 07:13 PM
Tags
0w, 0w20, 0w20manual, 20, 520sp, 5w20, accord, automobile, engine, honda, motor, oil, recommends, specs, weight
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
