0W20 Engine Oil?
0W20 Engine Oil?
The Honda owner manual recommends using 0W20 synthetic engine oil in their new Accord. I believe Toyota is doing the same. From what I've read, this oil was developed to help the manufacturers meet fuel economy federal guideline requirements for certain type cars by helping the overall average MPG across the board.
My question is, "Is 0W20 the best oil to use for protecting the life of the engine, or, is the best oil to use to help Honda meet fuel mileage guidelines?" Honda states that 5W20 is acceptable in lieu of 0W20.
I want to use the best oil for the life and lubrication needs of the engine. I don't really care about helping Honda meet fuel economy standards if it means using a thinner less lubricating oil.
So, what weight of synthetic oil do you recommend? FYI, I live in the Houston, TX area so cold temperature is not a concern.
thanks...............
0 weight has the consistency of water.
I couldn't imagine that it give much long term protection against wear on the metal parts of the engine. I would not run it my car that I was going to keep for a while even if it was recommended my Honda. IMO
well yes I would guess so but I think they (Honda) might be sacrificing longevity (cuase there is not much money in it for them for us to drive these cars 20+ years) for MPG which does sell cars.
I run 5 weight in my sportbikes but I def do not expect them to last much more than 30-50k miles. However I want want my Honda (car) to last 300K miles.
For the newer cars that recommend 0W-20 or 5W-20, these oil viscosity are used for fuel economy; but, at the same time provide protection for the engine. Many of the oils sold under these viscosity meet GF-4 standards. Generally, the motor should out-last many other parts of the car if you do regular recommended maintenance, check fluid levels, etc. Mobil 1 0W-20 and 5W-20 meet GF-4 standards, as well as many other quality synthetics out there.
I have close to 90K on my 2009 already.
OP is talking about a new Accord, right? Designed with the bearing clearances appropriate for a 20 weight oil.
Oil "weight" numbers are an archaic system that relates to viscosity in a very obscure way.
The number without the "W" is the weight of the oil, so 20-weight is what your engine calls for. There is no lubricating oil having a viscosity that's constant over the range of temperatures from 32F to 220F.
0W means "winter" and so when the oil is at a temperature of 32.F it has the viscosity of a "0-weight" oil. That's still A LOT thicker than a 20-weight oil at operating temperature. So even though it says 0w, it's not really a 0-weight oil. Confused yet?
Zero-weight having the consistency of water? I gotta do some homework with actual viscosity numbers, but I don't think that's true.
Tenbrooks, you think like I do, so we're both right!
Like you, my concern is engine longevity w/ minimum problems, not 0.13% better fuel economy.
I've always used the thicker oil option, 5W-20 in your case, as long as the temp ranges
match up to the owners manual. Houston is - duh - hot, too.
0W means "winter" and so when the oil is at a temperature of 32.F it has the viscosity of a "0-weight" oil. That's still A LOT thicker than a 20-weight oil at operating temperature. So even though it says 0w, it's not really a 0-weight oil. Confused yet? --YES
