1989 Accord cold idle :)
What I would do is take a look down the "throat" of that carb as it is running - yes you will have to use you hand on the throttle linkage/cable based upon your description - won't stay running unless you press the gas.
Are you seeing any gas "drops" or anything like that, might need a flashlight to get a good look.
Also look at the drivers/left side of the carb, there is a "sight glass" where you can see the level of gas in the bowl - again with age that glass "window" gets cloudy so a flashlight might be needed.
d0n
12-10-2014 07:42 AM
Mrowkoob66
11-01-2011 10:04 AM
